Author Topic: RTL-SDR TCXO Upgrade  (Read 12264 times)
Offline cdev
Re: RTL-SDR TCXO Upgrade
« Reply #25 on: October 27, 2017, 05:22:50 pm »
You should take a photo of your setup - maybe there is some basic thing that will be obvious from a photo.
If you're talking about direct sampling, it is what it is.
Its not a $90 or more HF-optimized SDR, and it will never be. Its a inexpensive DVB-T dongle with wires connecting it to an HF antenna, a use it was never made for. They are TV cards.
As far as I know, of at least a half dozen manufacturers whose names have come up at various times in this context, only Mirics has ever mentioned using their (still mostly intended for TV use) digital tuner chips for SDR.
Still..
Its a very very simple mod as they go and the parts are so cheap as to be affordable for almost anybody.
Likewise with a loop antenna. A loop is as good as it gets in a limited space but its optimized for a single frequency at any particular moment, its resonant frequency. And a given diameter loop will perform best in a limited range.
Still, hams use them all the time to work DX all around the world, even on low power. Ships at sea use them because they are compact and work.
Somebody can build a loop out of everyday household items, even the capacitor.
Loops work great for direct sampling.
From what ive read I actually think that the direct sampling SDR situation certainly can be optimized quite a bit more than Ive seen it done so far.
I bet another 6 db or more of S/N ratio would likely be easy to get by better matching the input to the RTL chip.
It appears the RTLSDR blog dongle has connections for i2c also brought out. So its essentially an RTL2832 breakout board.
Has anybody here used its i2c bus to talk to the RTL outside of the usual way via the RTL chip and the osmocom driver?
« Last Edit: October 27, 2017, 05:36:14 pm by cdev »
Offline bjcuizonTopic starter
  • RF and Analog Electronics Enthusiast
« Reply #26 on: October 28, 2017, 11:02:20 pm »
By the way, I have one question (well not related the OP  ::))...Is the input impedance of the V3 dongle 50 \$\Omega\$ or 75 \$\Omega\$?
I read that the generic dongles have a 75 \$\Omega\$ input but then they, the rtl-sdr blog admin, said that the mismatch loss between 75 \$\Omega\$ dongle and 50 \$\Omega\$antenna will be less (~0.2dB).
But then I thought that they might have placed a matching circuit for it in the V3. So does anyone know?
Thanks. :)
Don't mess with an Electronics Engineer, it Megahertz!
Offline medical-nerd
  • What's that coming over the hill?
« Reply #27 on: October 28, 2017, 11:05:32 pm »
Hiya
The input impedance of the V3 dongle is 50ohm.
https://www.rtl-sdr.com/wp-content/uploads/2017/06/RTL-SDR-Blog-V3-Datasheet.pdf
(after reading this datasheet you will be unable to resist buying one!!!)
Cheers
« Last Edit: October 28, 2017, 11:08:40 pm by medical-nerd »
'better to burn out than fade away'
The following users thanked this post: bjcuizon
Offline cdev
« Reply #28 on: October 28, 2017, 11:25:21 pm »
The VHF/UHF input of the DVB-T dongles is nominally 75 - some may be 50 ohms, depending on if they had the factory make them from scratch using a different design.
The difference between 50 and 75 ohms on VHF input is fairly minor.
I was actually talking about the pins on the chip's impedance.
Its not the same thing.
As you can see here..  https://www.youtube.com/results?search_query=%22direct+sampling%22+RTL2832
Direct sampling is not the same at all as using a dongle on VHF and UHF.
For years now, people have been modifying their cheap RTLSDR dongles to use them for HF. Why not, since they cost so ,little and considering the price they work really well.
Pins 4 and 5 of the RTL2832 chip's input are used for HF when direct sampling
their input impedance is specified at something much higher than 75 or 50 ohms, plus its a differential pair.
Normally that input is not something consumers ever deal with because its not used on dongles with an R820T tuner chip.
But, its fairly easy and for another few dollars in parts (if that) you can set up a filter to filter out the various unwanted signals, so you can receive HF.
It seems that a number of companies that sell dongles - for example, RTLSDR blog and CosyCave, a UK company,  now sell dongles that make it significantly easier to do that by providing better access to the pads.
Most people shouldn't though unless they know what they are doing because otherwise, say if you just connect up wires with no protection for the inputs, the risk of frying your dongle with a bit of static electricity is substantial.
That said direct sampling isnt hard to do.
You dont need to buy a special dongle either, any of them make a good starting point.
This video shows what can be done direct sampling with a generic Newsky dongle - using a home made filter and RF amp daughter board setup.
« Last Edit: October 29, 2017, 12:20:45 am by cdev »
« Reply #29 on: October 29, 2017, 12:15:13 am »
Hiya
Cheers
Thanks for clarifying that @medical-nerd..and thanks for the datasheet link.
By the way, @cdev I asked the seller if they put esd protection on the direct sampling front end and they said they did. It's also mentioned on their datasheet that they have already put a "real ESD rated diode" and still kept the BAV99 diode just for clipping the strong signals.
Quote from: RTL-SDR Blog Datasheet
The BAV99 diode which is used on most RTL-SDR dongles is not a true ESD rated diode. We have added a
real ESD rated diode for better protection. The BAV99 remains in the circuit as it works a strong signal
clipper, which prevents damage to the R820T2 from overly strong signals. Please remember that not even
this will save your radio from a lightning strike or huge ESD impulse, and any permanently outdoor
mounted antenna system must have its own lightning and ESD protection.
Offline cdev
« Reply #30 on: October 29, 2017, 12:24:45 am »
The way thats worded its not at all clear he's referring to HF.
Where is the HF input,
I saw connections for other signals but not for the HF signals, where are they connected, also what do they do for low pass filtering and impedance matching? Or do they just break out the inputs.
If so, (if the HF leads specifically are not protected) given that they are fairly similar in the crucial respects I personally would rather risk one of my cheap-er dongles connecting to it for direct sampling.
One thing about using TVS diodes.. The voltage at the HF input may exceed 0.7 volts fairly consistently in high RF environments.
That causes all sorts of broadband garbage. Thats a good argument for preselection, especially, but if thats too complicated, then putting an AM broadcast band trap on any receiver you use for serious HF listening.
the same goes for below AM broadcast band.. There you need a low pass filter set at around 550 KHz..
At this point the main thing I want to use it for is stuff thats less than 1 Mhz. Thats where my usual HF receiver's coverage stops.
« Last Edit: October 29, 2017, 12:40:47 am by cdev »
« Reply #31 on: October 29, 2017, 01:17:33 am »
Hiya
I agree it is not clear if the direct sampling mode is protected from ESD damage, however unlike the cheaper generic dongles all inputs to this dongle (HF and above) use the SMA input connector.
From the rtl-sdr site:
'HF support via direct sampling. Connect an HF antenna directly to the SMA connector and tune from 500 kHz – 24 MHz with the direct sampling mod. (No hardware modding or soldering required)'
'Improved ESD protection on the radio front end. The BAV99 diode which is used on most dongles is not a true ESD rated diode. We have added a real ESD rated diode for better protection. The BAV99 remains in the circuit as a strong signal clipper, to prevent damage to the R820T2 from overly strong signals.'
'Improved front end circuit. The standard matching circuit on the RTL-SDR was designed for DVB-T use, and tends to attenuate signals above ~1 GHz. The new matching circuit has less attenuation above 1 GHz and similar performance below. We used very high quality, high SRF, high Q inductors in this circuit.'
 'Added several access pads on the PCB. Access pads for the unused GPIO pins, CLK in/out, 3.3V, GND and I2C pins have been added. The CLK input/output is disconnected by default (see change 6). Access pads for the I branch have also been added as some users and industrial customers are using these in special projects. These pads are only for advanced users who need them for special projects. Take care as these pins are not ESD protected.'
 'Added an experimental HF direct sampling circuit, which is diplexed out from the SMA connector. This has little to no effect on VHF/UHF operation, but allows us to make use of the Q branch on the RTL2832U chip for direct sampling, which allows us to receive from about 500 kHz to about 24 MHz. (Below 500 kHz is unavailable due to attenuation from the bias tee circuit). We used a ~10dB 50 Ohm preamp as a buffer and to overcome losses in the transformer and filter. We also added a strong 24 MHz low pass filter, and added an impedance matching transformer coil to ensure good direct sampling performance.'
So the access pads to clock and control signals are not ESD protected. The HF front end passes through a buffer which possibly provided some protection to the RTL2832U chip.
It is not specified if the input to the HF section is taken off before or after the 2 protection diodes.
Cheers
« Last Edit: October 29, 2017, 01:28:15 am by medical-nerd »
Offline cdev
« Reply #32 on: October 29, 2017, 01:21:49 am »
That sounds promising!
« Last Edit: October 29, 2017, 01:32:58 am by cdev »
« Reply #33 on: October 29, 2017, 02:02:55 am »
Hiya
There is a description of an enthusiast using the V3 dongle for HF here:
http://www.udxf.nl/The-RTL-SDR-V3.pdf
and the rtl-sdr site also describes a modification to the V3 dongle involving removing the bias-t inductor (L13 on the picture) to improve LF reception.
I can't find a circuit diagram or a detailed block diagram for the V3 but it seems that a BGA2867 mmic is used somewhere in the input path - the lower left part of the board picture.
Cheers
« Last Edit: October 29, 2017, 02:06:43 am by medical-nerd »
Offline cdev
« Reply #34 on: October 31, 2017, 10:37:11 pm »
It would likely be fairly straightforward to replace the "bias tee" setup on the dongles with a much better one. (For cost reasons I am sure the setup they come with is fairly minimal)
Minicircuits has a dedicated biastee that works well all across that range for around $6 in quantity. That would likely be the ticket if it can be inserted somewhere into the signal path in lieu of the other parts.
« Reply #35 on: November 03, 2017, 05:58:55 pm »
Hi, I have another question here....
(I'm like hijacking my own thread, hehe and I don't feel like making a new thread for it as it's just a short question.)
So I'm planning on building a quarter wave antenna out of solid core wire (probably 12AWG) but then I coudn't find anything like solid wire on websites of local harware stores or depots here in New Zealand. Most of the house wiring here is done in stranded core wires but from where I came from, they do it in solid...so I thought it would be the same.
Does any one know where to purchase such things. Or does anybody have some ideas on building it with different materials? Thanks, your help will be much appreciated.
« Last Edit: November 03, 2017, 08:26:28 pm by bjcuizon »
Offline metrologist
« Reply #36 on: November 03, 2017, 06:47:35 pm »
Is this for the upper bands and a small antenna? Maybe you could find small copper tube, like what is used to supply refrigerator ice cube makers? If for HF, maybe you can still use stranded, but it will likely stretch. You may also look for copper clad steel wire.
« Reply #37 on: November 03, 2017, 08:24:25 pm »
Ooops |O...Sorry I forgot to mention the band.
It's for VHF Airband  ;)
And I'm also probably making another smaller one for ADS-B reception.
Offline metrologist
« Reply #38 on: November 03, 2017, 08:45:29 pm »
I have recycled analog TV antenna's for VHF using the aluminum tubes and combination of rivets and screw clamps. Otherwise, higher bands work well using small brass or copper tubing.
Offline cdev
« Reply #39 on: November 03, 2017, 11:18:35 pm »
For ADSB (1090 MHz) a quarter wave whip is 68.75mm. You can make a tiny little ground plane. That works surprisingly well if its up a bit.
Or you can make a gain antenna. Try making a collinear antenna out of many short segments of coaxial cable and seal it into a piece of thin PVC pipe. (see https://www.balarad.net/ for example )
That can give you very high gain at the horizon. You can also make another variant of UHF collinear antenna that looks a lot like a VHF ground plane with short coiled stub sections along its length.
ADSB enthusiast web sites have dozens of designs. One thing that's cool about ADSB is that you can data mine your results to generate pretty pictures of your antennas coverage and compare them to one another.
« Last Edit: November 03, 2017, 11:44:12 pm by cdev »
« Reply #40 on: November 24, 2017, 12:59:17 am »
To no avail, there was no solid core wire in the local bunnings here in NZ. So I had to find a substitute.
I found some of those galvanized wire for fencing applications, (like the material used on those diamond shaped fences surrounding the airport), and made a dipole out of it. They were already cut to 300mm so I just had to connect 2 of them for a 600mm long radial which is 1/4wave of 124Megs (roughly the centre of the vhf air band).
I also decided not to solder the galvanized wire but instead use screw terminals so that I could just disassemble it and store it easily.
I mounted the whole thing on a wall and I connected some el-cheapo coax to it.
The results turned out to be good even if it was mounted inside I get a -10dB peak (on sdrsharp) when the gain is 28dB. (And I'm 5km from the airport)
As for ADS-B, I'll probably make a 1/4wave gnd plane or a dipole using some paper clips. :)...and wire some rg6 to it.
« Last Edit: November 24, 2017, 01:17:32 am by bjcuizon »
Offline cdev
« Reply #41 on: November 24, 2017, 01:04:59 am »
Are aircraft horizontal polarization?
« Reply #42 on: November 24, 2017, 01:06:21 am »
Oops...sorry, the pics are tilted (default setting of my tablet camera) :-//
Just tilt your head to the left ;D
By the way, that's the best spot I can get with very less noise. If I move it 20cm to the right the noise will significantly increase.
« Last Edit: November 24, 2017, 01:11:09 am by bjcuizon »
Offline cdev
« Reply #43 on: November 24, 2017, 01:55:17 am »
You need a balun!
Maybe you already have one if you have any 300 ohm to 75 ohm matching transformers?
« Reply #44 on: November 24, 2017, 04:22:56 am »
Yeah, I'll probably get one of those tv ant baluns on the hardware store. Those are 300 to 75 ohm, right?
Thanks.
Offline cdev
« Reply #45 on: November 24, 2017, 05:42:02 am »
They will work although the impedance of a dipole is 72 ohms so a 1:1 would be a better match at the resonant frequency. You could build a switchable 1:1 and 1:4 balun.. Use the elecraft modem design..
