Let's say I want to make big ass directional near field probe using waveguide. Like for 400MHz. It comes out like 15x7 inches. I can make this out of sheet metal.
It comes down to making a box that is open on one side with a rod going down in it. How do you do the calculations to design this?
I have seen a design that ignores the tuning screws for a 2.4ghz waveguide magnetron to coaxial connector (thought it is published by a neo nazi publication and I am not sure if I should link to the Zine here because its rather distasteful).
Is there a simple relationship that describes
-distance of injection probe from reflection wall
-length and height of waveguide
-minimum length of waveguide to be functional before open end
It's not great, but a bit easier then making a giant horn. Just curious really.
I was thinking about doing this for WR1500 waveguide. Perhaps making a set since its easy enough to make boxes out of thinner sheet metal.
Honestly, it would be easier to make a bunch of boxes then to design butterworth band pass filters for all this shit, you can make wr3200, wr1800, wr1500, wr1150, wr975 and nest them inside of each other for storage purposes then just use wideband amplifiers. It seems like less work and its smaller then a giant heavy ass dual ridge horn thats like 3x2x3 feet and weighs 25 to 40lbs (depending on materials thickness) compared to some dryer ducts and reinforcement wood, plus it seems reasonably directional.
A horn for the lower frequencies is ridiculous, it comes out to many hours of welding, cutting, and I don't even wanna think about fabricating the ridges. You need like 40 square feet of aluminum or more, and it cant be wobbly. Do I want to make one? yes. but this is really interesting due to the directional, cheapness and maneuverability from home depot so long its not mm wave dimensions.
I intend to make a higher frequency one first, for like WR975 dimensions, if I can figure out how to make the transition.
