Author Topic: Shortwave voice transmitter circuit ( not cw)  (Read 1718 times)
Offline Dom13cTopic starter
  • Lost in time, surrounded by evil and low on gas
« on: August 01, 2018, 11:23:28 am »
Transmitting voice over shortwave is quite fascinating to me.  But whenever I google for shortwave AM phone,  the results turn out as cw transmitters.Well, I've already made and played with them.  So my next goal is to transmit voice over shortwave.  Well ,don't recommend the SSB stuffs.  They are just too hard to be bulit. Output power may stay within one or two watt as I'm planning to drive a class B linear amplifier with it.( If possible suggest a circuit that is based on crystal oscillator) And I'm not talking about AM radio( 550-1500khz in India) transmitter , I'm talking about shortwave transmitter(3-30 mhz) with amplitude modulation
Online PA0PBZ
Re: Shortwave voice transmitter circuit ( not cw)
« Reply #1 on: August 01, 2018, 11:30:37 am »
Offline HB9EVI
« Reply #2 on: August 01, 2018, 11:53:15 am »
Try it with a NE602: http://www.elektronikbasteln.pl7.de/am-modulation-mit-einem-sa612-oder-sa602-ne612-ne602.html
with the trimmer you adjust the carrier suppression (if wished for SSB), otherwise it outputs an AM signal
Offline tkamiya
« Reply #3 on: August 08, 2018, 11:31:14 pm »
You might be better off googling "AM modulation circuit".
AM is nothing more than CW transmitter that is keyed down and power to the final section modulated.  There are much fancier way to do it but that's the basics of it.
Offline kg4arn
« Reply #4 on: August 09, 2018, 01:29:36 am »
http://www.phonestack.com/farhan/bitx.html
Check out how this ham did it. Very popular simple design.
Offline vk4ffab
« Reply #5 on: August 09, 2018, 07:22:42 am »
What you want to do is google DSB  Double Sideband, double sideband suppressed carrier. Its the easiest method of generating vioce RF. Peter Parkers Beach 40, the MDT by ozqrp etc are rigs that use direct conversion of audio to RF.
