Actually this is interdigital filter which allows for less spacing between resonators for same relative (fractional) bandwidth in comparison to combline, in other words it is more compact.
I guess threaded rods should work okay. Low surface loss of material is very important, if low insertion loss and/or narrow BW is required. I used tinned copper pipes, which could also be easily soldered to box walls.
