So i have a loop antenna i made that has a 1 meter diameter loop and a built in matched transistor differential amplifier type circuit at the base, along with an off switch relay, powered by phantom power.
Its rather large. Looks like a hoola hoop.
For active loop antennas, how would its performance look like if i made it say 1/3 the size, so that it could be portable?
The design i made is supposedly good for low khz to 30MHz.
What can i expect from this smaller loop? From cursory research i am lead to believe the results will be suprizing and not what i expect (shift in bw 3db points on both ends being uniform)
I basically built this with a matched transistor
http://www.pa1m.nl/pa1m/wp-content/uploads/2012/09/Loop-schematic.gifShort; what is the effect of keeping the preamp the same but changing coil diameter from 1 meter to one foot
