Low barrier (zero bias) schottky diodes are ideal but any small signal schottky diode will do. I have used 1N270s to good effect up to 1.2 GHz and they might be considered improved 1N34s. If you are going to directly drive a 50 or 100 microamp meter, then the diode type becomes less important as long as it is fast enough.
The detector configuration matters also. More complex designs forward bias the diode reducing the effect of forward voltage drop and may chop the input or use a second diode for temperature compensation.
If I were experimenting with a new biased detector design, I might use transistor base-emitter junctions as RF diodes.
