Hi
I brought a cheap Aliexpress SPF5189Z Low Noise RF amplifier and put it into an Aliexpress extruded case usable as a handle. The aim is to use this LNA with EMC probes to give the signal a low noise boost before the Siglent SSA3021 spec-an. The irony of using a low noise amplifier to measure noise is not lost on me. The SPF5189Z gain varies a lot over the frequency range.
The purpose of measuring the performance was that the SSA includes a feature to add gain corrections across a frequency range. By saving the measured gain of the SPF5189Z LNA, I could save that as a CSV file. This would allow me to generate a corrections file to upload back to the spec-an. Applying the corrections file across the entire bandwidth would allow me to normalise the gain to 0dBm. I can add to the corrections file the gain of any connected antenna. That is a very powerful feature because it will allow me to take direct readings from the spec-an.
The format of the COR corrections file is dead simple. It is
frequency (Hz), gain (dB). Below is a sample COR file created on the Siglent spec-an.
1000000,-25.00
10000000,-24.00
100000000,-20.00
1000000000,-14.00
2000000000,-10.00
I plan to use Excel to smooth the corrections data and reduce the number of data points.
The measurement test setup was as follows:
TG output >>>-----------------[10dB Attenuator]---| DUT LNA >----[10dB Attenuator]--------------->>>RF input
The LNA performs much as expected. One of the images shows what happens if the 10dB attenuator on the output is removed. The plot shows waves due to mis-match between the LNA output and the spec-an input.
A study of the photos will show that the power cable enters the aluminium enclosure through a rubber grommet. This is poor emc design because the sheild of the USB power cable is not grounded to the enclosure. Any noise on the outside of the USB shield will go straight into the enclosure. This risk is mitigated by the ferrite choke very near the power entry point. The prevents the whole USB power cable acting as an antenna.
One of the really nice features is that the LNA is a 5V device that can be supplied from the spec-an USB connector.
The correction feature is also really useful.
The combination of a dirt cheap LNA and aluminium enclosure now looks and performs reasonably well. Entirely adequate for the required purpose. The correction feature built into the SSA3021 spec-an will be use to make the LNA frequency response look flat.
Dazz
