Time Domain Reflectometers (TDRs) are a useful tool for testing cables and connectors, but just how useful are they for radio amateurs (hams)? The reason behind my question is that I have a spare Tektronix 1502, and I want to decide whether to sell it at a hamfest or on fleabay or somewhere else.
It is a small (30x13x40cm) portable oscilloscope with a 200mV ~50ps risetime step generator. It displays impedance as a function of distance and can:
- measure impedance variations in connectors/filters/antennas/PCBs
- locate short/open circuits and damage in cables
- locate intermittent faults in cables and connectors
- locate connectors in cables
but it cannot tolerate any external voltage in the cable.
The traditionally simple first example shows measuring cable length and impedance: a 2m 50ohm cable, a connector, a 1.2m 75ohm cable, an open circuit "termination".
The second example shows a 7.5cm 50ohm line terminated in a short circuit. This is
inside the Tek 1502, being the section of the stripline sampler between the BNC connector on the left and the sampling diode (SD). The short circuit is
inside the BNC connector; if there is static electricity inside a cable, it will be discharged while connecting the cable, before damaging the diodes. The scale can be seen from the IC with 0.1" pitch leads. The tunnel diode (TD) step generator is on the far right.
The third example is two 50ohm cables with an SMA connector. The expanded X and Y scales indicate that the connector is "visible" as a 2.5cm ~55ohm discontinuity.
The fourth example is two SMA T connectors in the middle of a 50ohm cable. Each connector is clearly visible as a separate "capacitative dip" in the reflected voltage, in between wiggles due to the connector/cable connection. Discontinuities 3.2cm apart are easily resolved, and it looks like it could resolve discontinuities 2cm apart.
The fifth example is two traces from a subtly broken cable. Moving the cable/connector made easily visible and significant changes.
My unit is functional with unimportant (to me) limitations.
- there is case damage which I repaired with methylene chloride solvent, but it would be unwise to use it in a wet environment, e.g. the Patriot missile defence systems mentioned in a service manual
- the NiCd battery pack was defective and the undervoltage/overvoltage protection prevented the 1502 turning on. I'm only interested in mains-powered operation, I use a homebrew "battery emulator". It should be possible to replace the NiCds with NiMH cells
- the chart recorder works, but I don't know where you could get a fresh supply of thermal paper. The recorder draws too much current to be used without the battery pack, but can be used if a 12V PSU is connected to the battery terminals with a flying lead and 4mm banana sockets
- for "hardcopy" I replace the chart recorder with a homebrew "XY output" and a DSO or XY pen plotter
So if you are a radio ham, what , if anything, would you use such a unit for?
