One reason not to place them closely together is to prevent the kickout from the sampling strobe from prematurely triggering the tunnel diode as the trigger pulse arrives. When using tunnel diode pulse generators in sampling applications, it is sometimes necessary to add an external delay line to the tunnel diode pulse generator because of this.
