Thanks for the answers guys.
Ok, Im not for example some 15 year old kid that want to spy on someone or whatever, I´m way past that age.
I only make this circuit as a challenge for my self to see how small I could get the circuit and I use the BC847 sot-323 as the PCB for the components so its a little bid fiddly to change anything to say the least since everything is as one sort of speak.
The page where I bought the inductor I remember it showed a Q of 16 for this which I decided would be borderline ok for this schematic, so that is the reason I bought it.
But since this now doesnt work I downloaded the datasheet and yes it show it only have a pitty Q of 8 att 100Mhz.. I had my thoughts.
Its Wurtz:
http://katalog.we-online.de/pbs/datasheet/744784210A.pdfBut I bought it from a Wurth reseller, I think either I bought wrong type or they had the wrong info about it since it show that is sure doesn't have a Q of 16, which of course explanes it all.
They don´t have any 0402 with higher Q as it seem within a reasonable value I guess so I have to stick with this one atm and hope for the best.
I will try to give it some HLR with another 4.7pF and see since its the smallest value I have right now but a combined value of 9.4pF feels a little to big, but I will see.
This circuit is far faar from the best, we all very well know that, but I choose it since I saw it to have a have good potential to make it very small since the components would fit just fine on the transistor, nothing else.
The BC847 and BC850 was what I had at home at the time I build it and since sot-23 is bigger then sot-323 thus the latter was the one I used. I was worried about the Ft of 100Mhz on both builds, be sure about that, but as mentioned it was a minimum so I kinda saw at least that part should work and the frequency used is just below about 90Mhz and even it is a borderline so is it lower then 100Mhz.
The transistors were bought from Digi-Key so I expect them to be ok, but sure you never know but I still would have my doubts.
The inductor must of course be the problem and I really hope it could work with little more capacitance because it would be a real pain to change anything out, but I have to do that anyway later on if this would work but only then.
