Hello guys (and girls if any) !!
I am trying to build a tunable RF transmitter using the AD9851 module which frequency is controlled by an Arduino. Sorry for the hand drawing in the attachment but this is what I tried building and It worked, well, sort of, but It transmitted a 12MHz wave (SW band) and I was able to hear the channel using a normal handheld radio set on receiving SW bands where the antenna is so long(In meters).
Problem is
1- Much noise is in the transmission, how to remove it?
2- Low power, how to increase it?
3- I used the toroid and a LAN wire (the single core wires which have many colors found in any LAN cable) forming 12 turns on one side and 3 turns on the antenna side, what would be better to use?
What I actually want is to build a frequency controlled transmitter which is able to transmit a clear audio for about 1Km on any wave band that might suit me but let us focus on FM and SW wave bands (Mhz range)
Any Ideas are so much welcomed
