RF fellows,
thanks for your suggestions.
@ Tomorokoshi:
I have checked the spectrum and I can't see anything but the FM band.
I think that the probe cable acts as an antenna because I clearly
see in the spectrum a 88-108MHz rectangle. I discovered that just after
buying the scope and since then I always use some filtering.
I don't have any switching power supply (I use batteries), so there
shouldn't be any RF source around.
@ Ian.M:
I have measured the oscillator output by means of a calibrated
RF probe, after applying a cap trimmer in series with the crystal.
I did that with the 4MHz HC49U crystal (the one that exhibits more
of that unwanted modulation) and the 6553kHz crystal (the one that
shows little or no modulation).
With the 4MHz HC49U crystal I got
- 1.168V DVM reading (which is about 1.3Vpp according to the
probe manual) when the cap trimmer is fully closed (max.
capacitance, 100pF),
- 1.163V (also about 1.3Vpp) with cap 3/4 closed
- 1.148V (1.25Vpp) with cap half closed
- 1.103V (1.2Vpp) with cap at 1/4
- 0.478V (0.6Vpp) with cap open (min. capacitance, it should be 5pF)
With the 6553kHz crystal I got
- 1.147V (1.25Vpp) with cap fully closed
- 1.121V (1.2Vpp) with cap half closed
- 0.894V (1 Vpp) with cap almost open (oscillation stops when it
is fully open)
Such values seem pretty consistent with what I measured with the
scope and pretty linear. If I understand the purpose of this
test, an actual modulation should cause some spike in the readings,
correct ?
@David Hess and voltz:
as suggested, I have put a 5-100pF capacitive trimmer in series with
the crystal, and this is what I got.
The frequency of the unwanted modulation changes wildly when turning
the cap with the 4MHz crystals (both the HC49S and the HC49S), while
it basically doesn't change with the remaining crystals.
Unfortunately I haven't got any crystal which is exact multiple of
1MHz, other that one of 18MHz, so I tried that too and it also behaves
exactly like the 4MHz crystals in this respect. In detail:
- the 4MHz HC49S crystal shows a 88Hz modulation when the cap is fully
closed (it was 150Hz with no cap), 6.6Hz when it is half closed, and
205Hz when the cap is almost open (oscillation stops if fully open)
- the 4MHz HC49U crystal shows a 463Hz modulation when the cap is
closed (it was 600Hz with no cap), 290Hz when it is half closed, and
2.2kHz when it is open
- the 18MHz crystal shows a 1.6kHz modulation when the cap is fully
closed and 595Hz when it is half closed (oscillation stops turning
the cap any further)
With the three crystal above, the scope behaves in a particular way:
when increasing the time base I see that sort of snake on the screen,
well, increasing the time base a little further makes a sinusoid
to appear on the screen which has the same amplitude as the fundamental,
it looks the same as the fundamental, but the scope cannot trigger it.
This behaviour is quite unclear to me and sounds very much like
an artifact. That doesn't happen with any of the remaining crystals.
- the 3932kHz crystal exhibits a small modulation with 40us period
which doesn't change turning the cap
- the 3579kHz crystal exhibits a small modulation with 20us period
which doesn't change much either turning the cap
- the 6144kHz crystal exhibits a small modulation with 200us period
when the cap is closed and 140us when the cap is half closed, then
disappears
- the 6553kHz crystal doesn't exhibit any measurable modulation, just
the mains (50Hz) or harmonics of that appears, very low in amplitude
(full data and pics are in the zipped attachment)
As I understand your point, this should prove that the unwanted
modulation I see on the scope screen is actually not there.
This raises a question though. When I noticed all that first in my
transceiver, it was caused by a 4MHz crystal in the LO that made
a 800Hz modulation to appear (that was the crystal I threw away
because I thought it was faulty
). What struck me was that I
found the very same modulation in the tx output measuring across
the dummy load, so I thought there was an actual parasitic modulation
that travelled through the entire tx chain up to the output (pictures
of that are in first post).
Now, if that 800Hz in LO was actually not there because it was just
"mixing between the sampling frequency and the oscillator frequency"
how do you explain the 800Hz in the tx output ? Is it not there
either and also caused by the same artifact ?
If this is the case, that would also explain the discrepancy between
my wattmeter reading and the power computed based on the scope
measurement, which is always in excess.
And, most important, if there is indeed such artifact, how can I
workaround it ? Is there a way to regain trust in my scope ?
You know, if I spot a 50Hz or 100Hz in the scope screen I easily
understand what the source is and dismiss it, but how am I supposed
to recognize the cause of a 833Hz ghost modulation which unfortunately
looks real to peasants like me
I'm looking forward to hearing your comments.
Thanks
Maurizio
