I wasnt sure if I would get more answers here or in the test equipment forum but im hoping some one here knows a bit about this topic. I found an article about a diy lock in amp and realized I have all the chips to build it, Ive read up alot on it but I haven't seen these used in RF at all and cant figure out why. My idea is to downconvert l band an 70c'ish frequencies down and feed them in to the lock in amp, and use and RF signal gen to feed the carrier input, then feed the data in to an SDR or ADC.
From what I can tell a lock in amp will dig signals out of the noise floor be comparing there phase with the carrier reference, what I dont really understand if I downconvert things like the natural hydrogen line spike or complex signals like qam for a sat, will the lock in amp reconstruct them properly by just feeding it the correct carrier and if so why am I not seeing all kinds of people using these for space comms or HF weak signal, etc. I have a feeling im missing the limits of what this tool can do, i.e I don't want to waste time putting one together if all I can do is dig weak signals out of the noise for simple things like photo transistors and other analog sensors with simple output.
