I decided to give this a try too, so I got some Molex surface-mount SMA connectors, a bunch of 0805 and 0603 resistors, and my new-to-me HP 8714ES VNA.
For calibration, I used a homemade OSL cal kit using the same Molex female SMA connectors and two 0603 1% Yageo 100 ohm resistors soldered in parallel to what would be the board side of those connectors. Generally, the
IN3OTD approach.
For the unequal resistors, I used 51 ohm and 2700 ohm (nominal) resistors. I picked from sets of 6 of each of them for the match that would be closest to a DC resistance of 50 ohms when in parallel.
I did the experiment several times with each of the sizes of resistors and got basically the same results, so I'll describe only the 0805 case in detail here.
The 51 ohm resistor was measured to be 51.04 ohms, and the 2700 ohm resistor was measured to be 2662 ohms. In parallel, once soldered to the SMA connector, the DC resistance was 50.06 ohms.
I also made a nearly identical setup with 0805 100 ohm resistors in parallel. Its DC resistance was 50.05 ohms.
And now, the results.
Here's the log magnitude (Green = 51||2k7, yellow = 100||100):
The impedance magnitude (Green = 51||2k7, yellow = 100||100):
The Smith chart (Green = 51||2k7, yellow = 100||100):
The Smith chart zoomed in (Green = 51||2k7, yellow = 100||100):
The Smith chart with some markers, but just for the 51||2k7 case (Yellow = 51||2k7):
I was a bit surprised by the divergence -- particularly the fact that the impedance magnitude went up with frequency instead of down -- so I ran this many times, using different SMA connectors, different resistors (but the same values), and so on. The results varied very slightly from setup to setup, but they were always like what I described above in general terms.
I mean, I was expecting the behavior with the unequal resistors to be a little different, but not *this* different. I'm still relatively new to the world of VNAs, so if it looks/sounds like I was doing something wrong in my experimental setup, I'd like to hear about it.
Anyhow, just thought that was interesting. There is indeed a difference.
