A further update on this...
After thoroughly destroying a whole strip of varactors, I looked at some other diodes. Turns out your common garden red LED does the job quite well. I used the ideas here as inspiration:
http://www.hanssummers.com/varicap/varicapled.htmlSo thanks to some inspiration from another forum member as well, I now have the following tuning arrangement:
* Stable tuning voltage reference provided by a 78L05 and divider to provide output up to 9v.
* Course tuning via 10k pot
* Fine tuning via 10k pot
* Summing amp based on the other 1/2 of the LM358
* Hand selected (from about 50) generic red 5mm LED used as a varactor diode.
This gives me actually not too non linear tuning over 6.9-7.5MHz with no expensive air variables, nasty little SMD varactors or reduction drive. Drift of about 400Hz between 15oC and 25oC which will be improved when my CPC order arrives as I didn't use NP0 caps in a couple of places (because everyone was out of stock) and the assembly is poorly breadboarded deadbug at the moment.
Now for the mixer, front end attenuator and bandpass...
