Author Topic: Variable Capacitor Sealed In Oil  (Read 2168 times)
Offline Yavin101Topic starter
« on: December 18, 2017, 11:13:43 pm »
I came across this variable cap at a junk sale, and was wondering if anyone had any info about it. I put a meter on it and got a reading of (30pf -> 800pf) @ 1kHz)  I cannot find anything about it on Internet searches (except for a eBay listing with no information,)  just looking for any type of datasheet or information about its original uses.  Thank you
Offline xwarp
Re: Variable Capacitor Sealed In Oil
« Reply #1 on: December 19, 2017, 12:41:24 am »
Looks military grade. Post about this here and I'll bet you get an answer:
http://www.antiqueradios.com/forums/viewforum.php?f=5&sid=6cc28cf95602f7737ca73d2cf8a67881
The following users thanked this post: Yavin101
Offline TheSteve
  • Living the Dream
« Reply #2 on: December 20, 2017, 01:56:53 am »
I have no info to share but do think it's very very cool. I wonder what the break down voltage is with the oil.
VE7FM
« Reply #3 on: December 20, 2017, 03:31:24 am »
The info I received from antiqueradios.com/forums is that its WWII surplus equipment.
http://antiqueradios.com/forums/viewtopic.php?f=19&t=332790&p=2786256#p2786256
Offline Cyberdragon
« Reply #4 on: December 29, 2017, 01:57:02 am »
It's probably a transmitter tuning capacitor. It's used in the output section of a high power amplifier to either tune the output or the antenna. I've never seen a clear one like that though.
*BZZZZZZAAAAAP*
Voltamort strikes again!
« Reply #5 on: March 09, 2018, 07:36:12 pm »
I used it to tune a homebrew long wire antenna. the wire is 256' with a coil. it works well on 80 and 40 meters. SWR of 1.1 at 7.189 MHz and 1.3 on 3.968 MHz. I still plan on building a magnetic loop antenna for 40 and 20 meters.
