My understanding of APRS is that the frequency used is region specific. In North America, all APRS stations should be on 144.39. Digipeaters will receive and then repeat the same digital stream on the same frequency it was received, in a serial fashion.
I am looking on APRS.fi website. One thing I cannot determine is what are all the stations? I know there is a code used for your icon and I do not see a place for me to change that in my device software. Anyway, some stations show up as a star with a letter, some are diamonds with a letter, some are a big fat X, many are car icons, and the most, by a factor of at least 10, are WX stations, everywhere!
Ok, when I hover over a car icon, I see a path to a green star with an "I" in it 10 miles away. The path continues to a star with a D in it another 20 miles away, which happens to show it is an digipeater and igate. There is a star about 500 feet away from the car icon that says it is a digipeater and igate too. Why the signal makes hops rather than going right to the nearby station? What about all the other dozen stations that are closer than 10 miles away? Is it like a sperm when penetrating the egg, there is a signal to not allow any more sperms inside the network?
But more importantly, my signal should be received by any of the numerous stations around, and it only seems to go to one station and relays to another a much further distance away. I just wonder about all those other stations around and why the signals seem to make the same hops to the same stations. Also, I have programmed Wide 1-1 Wide 2-2 and I never see any more than one hop from a station (that I would think is already an igate) to another igate. It seems a statistical improbability that my signal will consistently make it onto the network from inside my building every time I turn it on without fail, at least once, but have less than 1/100 the connection rate when outside wandering/riding around with the antenna out in the open air, held over my head, across long distances, past many stations... Makes no sense whatsoever.
My device is a commercial AP510 APRS digipeater device sold by some Chinese or Japanese mfg. called SainSonic. Details of the device are easy to find on the website. I do not think there is a malfunction of the device, but rather I need a better understanding of the APRS system and why it's not working for me. I suspect there is a lot of traffic and signals are interfering, and my signal is very weak to start with. Even so, the generalized performance does not make sense to me. I'd also like to understand aprs.fi better, like what do the icons really mean? How can I find all the igates around me? What symbols to they use. I do not see a legend on that site, which seems so incredibly odd. Who makes a map with a bunch of icons and no legend, especially someone smart enough to put such a system together?
