Hello,
I want to make a simple upconverter thats optimized for the bottom 550 KHz of signals (converting them to something higher.)
Ive seen NE612 used in a DCF77 receiver so I am optimistic.
I have a large ferrite rod coming on order and so I plan to make an upconverter that allows the balanced input on the Ne612 to be used.
With the option to use either the loop or an unbalanced antenna.
Does this sound like a good plan?
I have an older upconverter which I'm going to reuse in part. I'm a little worried about ESD on the inputs so I want to use a transformer to galvanically isolate the input. Is that enough?
I think I am going to use either an Arnold molybendenum iron powder core I have or #2 material. The transformer is the part that I wish that I had a better level of knowledge on.
I want a tunable input stage with high selectivity.
