Author Topic: What is meant by solid ground plane ?  (Read 1911 times)
Offline madhu.wesly01Topic starter
  • Country: in
  • If you want to be happy, BE!
« on: May 04, 2018, 12:35:34 pm »
I am unable to understand, what is meant by a solid ground plane? :-//
In the datasheets, some of the manufacturers mention 'Maintain a solid ground plane underneath the module'
Does that mean
'I shouldn't have any traces, vias underneath the module'
                               or/and
'I should have a continuous ground plane without any islands?'
Please help me in understanding this
Thanks in advance
Offline Rerouter
Re: What is meant by solid ground plane ?
« Reply #1 on: May 04, 2018, 12:59:51 pm »
The overkill meaning is to have absolutely no breaks in the copper layer under the module what so ever
The more realistic approach is to ensure any fast signals do not cross any breaks in a ground plane where possible, and to plan your return currents to make sure they can follow your signal.
E.g. you have 2 signals that cross on the top and bottom layer, well the return current on a high speed signals wants to be as close to the signal trace as possible, generally following it on the ground plane underneath the signal, you have to allow a way for that return current to follow that signal past where it crosses the other to prevent it detouring around, which makes it both more likley to radiate noise, but also be suseptible to it.
One approach would be to provide some via stitching around the crossing so each return current can jump to the other side, adjacent to the signal, continue past the break, then jump back down. its not perfect, but its far better than the alternatives.
At higher speeds these breaks would also appear as impedance mis-matches, as the return current has to pass through a higher impedance per unit length of signal trace.
And to set the concept straight in your head, generally when the voltage changes on a pin, there will be a current loop formed, from that pin it likely goes to the supply rail of that chip, through your voltage rail, to whatever other chips supply rail pin, then completing on its input pin.
« Last Edit: May 04, 2018, 01:03:00 pm by Rerouter »
The following users thanked this post: madhu.wesly01
Offline German_EE
« Reply #2 on: May 07, 2018, 06:43:10 pm »
In my experience a 'solid' ground plane is one that is unbroken by extra traces that couldn't fit on other layers. This is wht four-layer PCBs are so attractive, power and ground on the inside layers and signals on the top and bottom. Extra marks if you can keep the RF signals on the top and everything else on the bottom.
Warren Buffett
Offline grifftech
    • youtube channel
« Reply #3 on: May 24, 2018, 05:41:58 pm »
here is the opposite (Grid)
