Looks like the bulkhead assembly from a HPAK 8400 series H-variant sensor. If you download the manual for the 8481H there is a procedure to test that assembly.
Actually looking closer at the 2nd image, there should be 2 very fine gold wires coming from those little bumps on the ceramic insert (which will be the matched thermocouples (or diode detector if this is an earlier model). Anyway those wires feed into the input amplifier and are critical to the correct working on the unit - So if they're missing then it might already be dead or unusable.
TonyG
