If your working band only goes to ~2.5Ghz, you will find that you don't need to spend anything like that to get perfectly good results.
I know the 8753D or even a 8753C (Which I own) is old but they still produce perfectly good results about as well as anything more modern, and I would expect to buy four with change for the cal kit(s) for that money. The real expense here is in the calibration kits and the test port extensions.
If you wanted something a little classier, then a PNA should be doable, has the advantage of direct support for TRL calibration which makes the cal kit pain a bit less tedious.
If you have money to burn then go for the PNA-X or such, drooool.
Most VNAs do not make very good spectrum analysers, I would probably make that a separate box, apart from anything else, you want to see harmonics, which means that if your working band is 2.5GHz you want to see out to 20GHz or so, a 20GHz SA is **MUCH** cheaper then a 20GHz VNA.
Have a look at folk like Copper Mountain, particularly if you are pushed for lab space, and R&S are always a good option but IMHO there is a reason the HP stuff is so popular.
Regards, Dan.
