We are seeing a trend toward stand alone SDRs and hopefully the kits will catch up.
In the meantime, why not use something like SDRplay with tablets or netbooks?
That would be fun and they are cheap.
Right now the project list goes like this.
1. Get the Inlogis loop up; that is the main component of the noise canceling project to try and knock the noise on 75 down to a reasonable S-3.
2. Phase 2 of Oscar's Rehab This involves installing a W7RY QSK mod in a Heath SB-220 which has had the power supply reworked. (see SB-220 Find on QRZ.com).
3. the fourth shelf for the desk, the desk is usable as it is now, but needs a fourth shelf so I can get another radio in for use, which leads us to the next project....
4. Put the IC-211 on our club repeater, Why? Why not, a fun project that involves adding PL to the IC-211, putting up a 3 element beam on the same rotor the InLogis loop is currently on.
All these projects take money, right now I have a decent chunk of change sunk in project #1, it needs to get finished, besides I will be doing a presentation on it to our club in January.
Then there are the projects waiting..........
1. four radios needing some TLC (TS-820, IC-745, SB-301, Drake R-4A,) they all work just not as well as they could except for the SB-301 it needs to be re capped and the decoupling resistors need replaced. The SB-301 works but only if you consider 500 microvolts to be acceptable.
Then there is the test equipment waiting in the garage, along with a fairly rare home brew pair of receivers that were featured in QST in the early sixties, I have an HBR-14 and an HBR-16 that look too close to the ones featured in the articles. The test equipment are a pair of Tek 475s one is a hanger queen and the other one looks fixable and of all things an Eico VTVM that I want to restore, just because.
