This is actually for the jim williams 100KHz preamplifier for noise measurements, I doubt it has any business connected to a SDR.
Should I lift the 0V (its powered by +-4.5V from a lab PSU or a internal switched in batteries) from the chassis, have it enter through a feed through, and go directly to the PCB?
It just seems odd to connect the ground through a feed through (the +-4.5V are isolated bananas, but the 0V is a grounded solid metal banana). I don't really see the problem the ground loop between the interior of the chassis and the heavy gauge ground wire causing a problem with a system consisting of a few op-amps.
I also need to know this because I have the parts to build a active RF circulator with high speed op-amps which will have the same problem.. I was planning on using RF-Feedthrough caps on the +-rails and bonding the 0V ground at both the PCB and the chassis.
It defiantly seems weird to use the chassis as a ground return (is this good practice at all?). To be honest I also questioned it with the bananas, and I was planning to actually make it twinax BNC instead of regular BNC, since the chassis is made of steel.
I thought small signals fine, it can go through the chassis through 4 star washers, but the power supply ground???
What should I do as best practice for this LNA that uses LT1028s? I mean there is a loop, but its inside. Does it pick up noise from the power wires? Also there are some capacitors between the 4.5's and ground (tantalum <100uF).
To be fair I only did it because I ran out of isolated banana plugs, but does it matter? I actually thought it was making it better because the loop is internal and im shorting out a peice of cable with a big sheet of steel so the impedance should be lower.
