I would like to measure the frequency response of some transformers I am winding to connect various wire antennas to various coax lines (50 Ohm or 75 Ohm, maybe even 100 Ohm CAT5 wiring). I would like to test various transformer core materials, winding methods, turn counts, etc.
The one I am testing now is designed to match an approximately 470 Ohm loop to 50 Ohm coax. I have a Keysight 1000X scope with the Frequency Response Analysis feature. This is similar to a Bode plot, but sadly nowhere near a VNA. Nevertheless, this is what I have to work with at the moment.
So I have a choice of having the wave gen built into the scope output 50 Ohms or Hi-Z. Since I want to put the wave gen into the 470 Ohm side I was using Hi-Z and using a 1X probe as my signal injection connection. Then I was connecting a 10X probe To the same terminals on the 470 Ohm side as my input sense connection (Ch1). (When I say terminals I mean my custom box has screw terminals for the 470 Ohm connection and an SO-239 for the 50 Ohm coax.)
I then connected a 50 Ohm RG-58 to the output of my transformer (it is in a box with an SO-239). I connected this to the scope as the output sense (Ch2). The scope does not have a 50 Ohm input, so I used a terminator at the scope end.
With the Ch 2 coax terminated I did not get much of a result curve. Un-terminated I saw a curve that looked fairly similar to the impedance curve of the torroid I used. I am also wondering if this isn’t a signal level issue. What signal level should I be using out of the wave gen? I know receive signals are very weak, but the wave gen will only go down to 2mV P-P. Using a higher level may give me a better response curve, no? How accurate would it be vs. actual received signals, though? I am using good sized torroid, so I don’t think I have to worry about saturation.
Any thoughts on how to best optimize this test setup for experimenting with different windings and cores? Is using Hi-Z out of the wave gen the correct approach? Do I need to put a 470 Ohm resistor at the input to get the source impedance correct? I am foggy on this.
Thanks in advance.
