Author Topic: How to design mains AC to DC adaptores, for small loads...  (Read 2536 times)
Offline FabiosapplouTopic starter
« on: April 25, 2017, 10:19:35 pm »
I'd really enjoy a take on how David would design a steep down mains adaptor to power small loads shuch as a esp8266... Not using the obvious route of a small transformer 50/60hz transformer with regulation...
Offline David Hess
  • DavidH
Re: How to design mains AC to DC adaptores, for small loads...
« Reply #1 on: April 26, 2017, 01:47:15 pm »
If you do not have other constraints, then there is another way to use a line frequency transformer; include the transformer for line isolation and follow it with a switching power supply.  A power factor correction stage could even be used to provide a unity power factor on the input.  There are also some EMI advantages since RF filtering can be done at a low voltage.
Online thm_w
  • Non-expert
« Reply #2 on: April 26, 2017, 08:09:51 pm »
Use an off the shelf module or an existing supply (like a USB supply) and integrate it into your design.
http://www.hlktech.net/product_detail.php?ProId=54
https://skippy.org.uk/quick-look-at-the-hlk-pm01/
I assume you care about low cost here, otherwise you can get good modules from digikey.
