If you do not have other constraints, then there is another way to use a line frequency transformer; include the transformer for line isolation and follow it with a switching power supply. A power factor correction stage could even be used to provide a unity power factor on the input. There are also some EMI advantages since RF filtering can be done at a low voltage.
