Load 1.28 m-firmware AY-AT, color now ok but response very very slow and rotary not run i can set only pwm.Any idea?Thanks
So now I am not sure what to do (to reiterate: the original AVR is probably fried as cause of charged capacitor testing and now the tester measures wrong values). Maybe I could replace whole PCB and DIY a new one, reusing only the LCD and use PDIP atmega328.
Grazie! I'll add it to the source. Some strings are a little be too long (max. 14 characters for menu items and 16 for other stuff to keep everything within the typical 16 char/line range).
Correct.
