They do not work out the same office, that's nonsense. For one you can see completely different software and hardware design concepts in teardowns and demo videos/reviews. For example Atten use non-45deg traces on the ADCs. Rigol don't. And I believe Atten used 4 x dual 80Msps ADC OC @ 125MHz instead of 5 x dual 40Msps ADC OC @ 100MHz in their 50/100MHz product.
The reason you're seeing information loss is going to be down to probing and the characteristics of the circuit. I have used my 1102E up to 100MHz with no "information loss".
And, as stated, these models have a deliberate ~130MHz filter, so their input bandwidth is not 200MHz. But the design is (theoretically) capable of around that. It's just limited to avoid aliasing.
