Author Topic: 2017 may, hack Rigol DS2072a-S Is it possible to unlock?  (Read 2914 times)
Offline ALeX_71
  • Country: ru
« on: May 12, 2017, 07:15:59 am »
Hello!
I wondered, is it possible to hack the DS2072A-S?
I'm choosing between 2 models DS2072A-S DS2072A.
DS2072A can hack for me, the seller. And about the DS2072A-S says they can't be hacked!
I found a method of breaking through RigolBildschirmkopi and rigup-0.4.2. ( http://www.eevblog.com/forum/testgear/unlockinghacking-the-rigol-ds2000a-series-scope-the-short-post/100/ ) Does anyone have some experience hacking DS2072a-S?
Help me, can someone make a dump of the firmware? Me a chance to practice working with programs hacking.
PS: is there any difference in hacking DS2072A, DS2072A-S, MSO2072A? Is there a difference in the type of firmware for these devices?
Offline thm_w
The following users thanked this post: ALeX_71
Offline CustomEngineerer
Re: 2017 may, hack Rigol DS2072a-S Is it possible to unlock?
« Reply #2 on: May 12, 2017, 09:41:58 am »
The only difference between the DS2072A and DS2072A-S is the -S version has the built in function generator. Other than that the hardwares are identical, they use the same exact firmware, the hack is the same for both. I have a DS2072A-S (yes it is hackable, seller doesn't know what he talking about), however I would recommend getting the one without the builtin generator because the builtin generator is a pain to control. Unless you just don't have the space for a separate standalone generator, don't waste your money on that option.
Edit: Wanted to add, don't pay extra for the seller to hack it for you. Its literally a 5 - 10 minute process that you can easily do yourself.
« Last Edit: May 12, 2017, 09:44:31 am by CustomEngineerer »
The following users thanked this post: tkarlmann, ALeX_71
Offline tkarlmann
« Reply #3 on: June 14, 2017, 01:09:55 pm »
Can you elaborate on the "pain to control" aspect of the DS2072A-S?
Offline nugglix
