Author Topic: Beginner - Spectrum Analyzer help and advice  (Read 2634 times)
Offline TomerTopic starter
  • Country: il
« on: January 15, 2018, 05:25:38 pm »
Hi all and thank you for helping out.
I am in the process of setting my lab, I intend to do Audio work and experiment/design Pro audio gear such as Preamps, Eq's, compressors and effects.
I will need a spectrum analyzer.
Can you guide me in the right direction for one, it can be PC based as well.
I was thinking to use a PICO 2000, but i saw that the resolution is 8Bit, I think that can be a problem with Audio ? don't you think ?
Thanks you and sorry for the general question.
Thx
Tom
Offline nctnico
Re: Beginner - Spectrum Analyzer help and advice
« Reply #1 on: January 15, 2018, 06:37:44 pm »
I think the Analog Discovery may fit your requirements.
  • Country: il
« Reply #2 on: January 15, 2018, 07:26:59 pm »
Thank you
Are you referring me to the following product ?
https://analogdiscovery.com/
Tom
Online RoGeorge
« Reply #3 on: January 15, 2018, 07:43:08 pm »
A good PC soundcard, like 24/192 or more, used as a spectrum analyzer. A dedicated SA instrument for audio doesn't make much sense.
Offline nctnico
« Reply #4 on: January 15, 2018, 08:19:40 pm »
Thank you
Yes, that is the one. IMHO the BNC adapter board is a nice to have as well.
The following users thanked this post: Tomer
  • Country: il
« Reply #5 on: January 16, 2018, 02:41:26 pm »
Hi and thank you for the replay.
I was thinking about using a sound card but, they can be very expensive with a lot of functions that i don't need.
Do you think a basic Studio sound card can be sufficient ? maybe you have a recommendation to one.
Thank you
Tom
Offline thm_w
  • Non-expert
« Reply #6 on: January 17, 2018, 11:10:58 pm »
Thank you
Tom
You need to be more specific, what is your budget and what do you need spec wise?
ie is 20Hz-50kHz enough, what THD level, inputs/output type, balanced in and out?
Scarlett solo and UMC204HD are some good <$100 choices, there are much better at higher prices though.
https://audiosciencereview.com/forum/index.php?threads/budget-dac-review-behringer-umc204hd.1658/
Offline Krytron
« Reply #7 on: January 18, 2018, 11:15:30 am »
"Posted by: RoGeorge
    Insert Quote  "A good PC soundcard, like 24/192 or more, used as a spectrum analyzer. A dedicated SA instrument for audio doesn't make much sense."
Consider that if you are working with very low level signals, that connecting a computer to the circuit may generate disturbances that will show up in your measurements and data".  Computers generate a lot of radio frequency interference.   You will note that a lot of computer inter connecting leads have ferrite cores at the ends near the connections and that acts as a low pass filter.  Cheap digital voltmeters can also spit a lot of EMI into your circuits, etc.
Online DimitriP
« Reply #8 on: January 18, 2018, 11:30:55 am »
Give visual analyzer a try.  http://www.sillanumsoft.org/
VA and RMAA are my two most favorites for double checking what my ears are hearing (or not ) :)
Offline IDEngineer
« Reply #9 on: January 18, 2018, 03:17:41 pm »
HP has been making audio-specific spectrum analyzers since at least the 70's (back when their catalogs were a hardbound book like an encyclopedia!) and they charged their usual prices for them. They made sense then, as they do now, if you're doing precise work.
However, you are correct about a sound-card-based solution for non-demanding work. I've had great luck with TrueRTA for many years, even used it to characterize filters in the audio range.
https://trueaudio.com/rta_abt1.htm
Disclaimer: I have no formal connection with them except as a satisfied customer. Definitely worth a look before you spend real money.
Offline DC1MC
