This is the last of the four DMMs I picked up a couple weeks ago,,, Its a Cen-Tech, but seems to be much better than the usual HF freebys,,, This one has a lot more ranges in each mode... Modemhead pointed out how sort out the really cheap DMMs, so I thought I'd add this one to the mix... Its got a few scratches on the display, but is very accurate in all the ranges I've tried so far,,, Doesn't have the Temp probe, but its not a big deal... It has a frequency mode I'm not sure how to use, but there is probably a manual available online...
All in all, when I sort the Fluke out, I should be good on DMMs for a while!!!
