I recently picked up a used Agilent 34401a DMM off of eBay. I love the meter and want to take advantage of it's remote control capability.
The meter has RS232 and GPIB interface, neither of which my PC has. I do think I have a USB -> Serial converter lying around somewhere, so I was thinking I would use that. Another option would be to get some sort of GPIB to USB converter or a GPIB board for my PC.
Is there any advantage to going the GPIB route here?
Thanks
Well, your PC normally has RS232 on the mainboard, only the D sub ( DB 9) plug is not assembled on the rear panel of your PC.
If you have some D sub 9 jacks in your stock, then it's cheap and easy to interface the HP34401A.
Decades ago, I even connected an HP48SX calculator to this instrument, so I think, the minimum 3 lines interface (RX, TX, GND) is sufficient for steering.
If you go for GPIB, you may better pick a National Instruments PCI bus card.
As surplus they may be available for less than 100€/$, plus cable(s).
That's much better, and you later can extend your system with other instruments.
Frank
