Hi folks,
it's my first time writing here as I hope you can help me out (like many times before as a reader of this forum
I'm a development engineer for rf electronics and software and an electronics and rf hobbyist.
A few days ago I've bought an Advantest R3961B S-Parameter test set which should be added to my 8753C with some glue logic, it's a test set specified from 300kHz up to 3.6 GHz but a quick hookup to our campany's VNA showed it works quite well up to 6 GHz with roughly 24 dB directivity.
Now I have a big problem with one of the N connector test ports on one of the directional bridges, the previous owner crapped the inner conductor
I've managed to disassemble the bridge and remove the connector but the conically shaped center conductor is broken.
Does anyone of you know which manufacturer builds similar tapered N connectors or where I can get a replacement?
Thanks a lot in advance!
Here some pics of the opened bridge, only taken with my mobile but I will add some better ones:
