Author Topic: Affordable Low frequency (< 1MHz) network anayzer  (Read 13842 times)
Offline JesterTopic starter
« on: September 21, 2016, 09:15:16 pm »
I did a google search and I'm not finding much, other than expensive instruments like the Keysight U8903.
I half expected a google search to yield some sort of USB based box with PC software that would sweep and analyze audio filters etc.
Surely there must be a better way than dialing up various values on the signal generator and measuring the response point by point?
Online nctnico
Re: Affordable Low frequency (< 1MHz) network anayzer
« Reply #1 on: September 21, 2016, 09:28:32 pm »
I recently picked up an Anritsu network analyser from Ebay. It could be a brand to look for.
Offline rfeecs
« Reply #2 on: September 21, 2016, 09:37:14 pm »
How about Analog Discovery:
http://store.digilentinc.com/analog-discovery-2-100msps-usb-oscilloscope-logic-analyzer-and-variable-power-supply/
Among other features:
Network analyzer – Bode, Nyquist, Nichols transfer diagrams of a circuit. Range: 1Hz to 10MHz
Depends on the frequency and dynamic range you are looking for.  There may be software to do it with a sound card.
Offline metrologist
« Reply #3 on: September 21, 2016, 09:57:15 pm »
N2PK
The following users thanked this post: electrolust
Offline MagicSmoker
« Reply #4 on: September 21, 2016, 10:23:22 pm »
Maybe consider scoring an old HP 3563A off ebay. They tend to go for $400 to $600 and cover DC to around 100kHz; that's more than enough span for characterizing audio circuits and note that the 3563A measures both phase and frequency response (ie - it is a proper vector network analyzer, just limited in frequency range).
If you want something more modern - albeit a bit more expensive - then perhaps consider the frequency response analyzer offerings from Cleverscope or Newtons4th.
Offline AR
« Reply #5 on: September 21, 2016, 10:38:16 pm »
There is the Digilent Analog Discovery USB Oscilloscope which has a built in network analyzer which is available  from mouser
  http://www.mouser.com/new/digilent/digilent-analog-discovery/
Offline Chris Jones
« Reply #6 on: September 22, 2016, 02:48:35 pm »
N2PK
+1 - Whilst I don't have one, I think this is a good option.
It drives the LO port of the mixer with a sine wave which is not ideal as switching mixers would have more temperature-stable gain if driven from a square wave, but it would be good enough for most things. For <1MHz it would be quite feasible to build an active s-parameter test set using differential amplifiers instead of transformers, to work down to lower frequencies.
Offline JLNY
« Reply #7 on: September 22, 2016, 06:49:39 pm »
Another option would be to use a spectrum analyzer and input white noise from a PC or something to get the audio frequency response. Alternatively, get an audio spectrum analyzer with a tracking generator.
In my own lab I have an HP 8556A/8552B spectrum analyzer plugin stack for an old 141T mainframe. The 8556A plugins are somewhat uncommon, but have a tracking generator built in. That said, a massive 141T from the 1970's is going to be quite a bit bigger than what you have in mind, so I suggest going the white noise route. given that a PC sound card can be used as a spectrum analyzer, you may have everything you need already.
Offline orin
« Reply #8 on: September 22, 2016, 07:10:21 pm »
See:  https://reference.digilentinc.com/reference/software/waveforms/waveforms-3/reference-manual
It looks like it would do the job nicely.  I was going to suggest the DG8SAQ VNWA, but it only goes down to 1kHz.
I have the original Digilent Analog Discovery, but I've never tried the network analyzer feature.
Offline ebclr
« Reply #9 on: September 22, 2016, 08:24:56 pm »
Offline ADT123
    • Pico Technology
Disclaimer: I have worked for Pico Technology for over 30 years and designed some of their early oscilloscopes.
We are always recruiting talented hardware and software engineers! Happy to answer Pico related questions when time permits but here as electronics is a hobby
Offline David Hess
  • DavidH
« Reply #11 on: September 23, 2016, 12:24:09 pm »
http://www.syscompdesign.com/Instruments_ep_42.html
This works pretty well if your DSO supports automatic measurements but an alternative is to use a sweep generator;  with the oscilloscope triggered at the start of the sweep, gated/windowed measurements can be made visually.
« Last Edit: September 23, 2016, 12:28:24 pm by David Hess »
Offline ebclr
« Reply #12 on: September 23, 2016, 07:56:58 pm »
White noise and a spectrum analyser is another way
Online nctnico
« Reply #13 on: September 23, 2016, 08:05:26 pm »
If you go that route an oscilloscope with good FFT (say 64kpoints or more) and a function generator (swept or noise) are also suitable unless you want to measure >24dB differences. However a network analyser will also show phase shift which is something you might be interested in especially when dealing with audio.
Offline David Hess
  • DavidH
« Reply #14 on: September 23, 2016, 10:33:51 pm »
If the stupid DSOs did not throw away the phase results when calculating FFTs, then they could also show phase shift.
Offline billfernandez
« Reply #15 on: September 24, 2016, 01:49:05 am »
If evaluating the frequency response of audio filters is what you're really after, look at the QuantAsylum QA401:
http://www.quantasylum.com/content/Products/QA401.aspx
« Reply #16 on: September 24, 2016, 07:24:19 pm »
Thanks for all the great leads. I may pick up the Digilent, looks like a fun toy/tool to play with.
Using the Tektronix-Excel add-in for my scope actually works reasonably well as long as I sweep the signal generator at a slow rate. This only takes seconds to configure and automates the tedious part. This method also has the advantage that I can run these tests into the  xxx Mhz range if desired.
This is a LPF I just tested using the Excel data capture add-in (100 or so test points)
One obvious downside is the dynamic range amplitude wise, when sweeping a steep filter, I hit the noise floor pretty quickly
« Last Edit: September 24, 2016, 07:35:02 pm by Jester »
Offline Insatman
  • Country: ph
« Reply #17 on: May 27, 2018, 07:09:32 am »
I started looking for some kind of low frequency SA again.  Something that would be able to do from 0.01 to 100kHz minumim.   I came across this piece of Chinese test gear
https://www.aliexpress.com/item/TDO3062BN-Digital-Storage-Oscilloscope-Low-frequency-Network-Analyzer/32855509772.html
the same unit sells on Ebay for ~$600 more than Aliexpress.  Attached is a datasheet.
Anyone have experience with this type of unit?  they also make two other versions, both with higher end frequency capability which I don't need, but experience with any of them would be helpful.
I've been trying to make a soundcard/software based SA work but so far the software just crashes when I try to get small spans and RBWs.   Even though the spec says it should work.  I'm using the software from Spyro Gumas (fatpigdog).  Hopefully my emails to him will result in some enlightenment.
Retired Pulsed Power Engineer/Physicist...now I just dabble in electronics
Offline precaud
    • LinearZ
« Reply #18 on: May 27, 2018, 03:36:46 pm »
A lot of vaguery in those specs. No mention of ADC bit depth, available input ranges, etc.
For basic specs, .08dB gain and 1º phase resolution is not very good.
For that kind of money, buying new I'd just step up into the Cleverscope CS320 VNA version.
In older used gear, the Anritsu MS's are excellent. HP 3577A's are becoming more affordable. If 100kHz is enough, HP 3562A is a great piece. But these are large items. Having worked with you before, we know that getting stuff to you can be "challenging"...
Offline Bud
« Reply #19 on: May 27, 2018, 04:44:57 pm »
« Last Edit: May 27, 2018, 04:47:16 pm by Bud »
Offline Bud
« Reply #20 on: May 27, 2018, 04:52:36 pm »
Offline _Wim_
« Reply #21 on: May 27, 2018, 05:39:48 pm »
What software package are you using? I had very good results with ARTA. For drives, I always use the ASIO drives for the soundcard, not windows WDM. Arta has a list with soundcards that were tested with their software: http://www.artalabs.hr/requirements.htm
The sound card approach is by far the cheapest option to get very good results. Disadvantages are that you have to take care of input levels and avoid ground loops. But you can achieve an THD+N below -105db with easy when using a decent sound card.
Offline JohnG
« Reply #22 on: May 27, 2018, 06:24:28 pm »
When I worked more in the audio frequency domain, I also got excellent results with ARTA. It is a very powerful software, and it does swept frequency, chirp, MLS, time-gated measurements and other analyses. The documentation is also very educational and worth a look on its own: http://www.artalabs.hr/download/ARTA-user-manual.pdf
John
"Reality is that which, when you quit believing in it, doesn't go away." Philip K. Dick (RIP).
Offline Insatman
  • Country: ph
« Reply #23 on: May 28, 2018, 08:07:23 am »
I download ARTA and it work well except that it is limited to 0.1Hz at the low end.  I need 0.01Hz.  This was probably because for audio 0.1Hz is plenty low, but I'm using this to characterize a 10000:1 amplifier with a bandpass of 0.1Hz to 10Hz.  So I need at least an order of magnitude below my low end to see the rolloff.
Offline precaud
    • LinearZ
« Reply #24 on: May 29, 2018, 01:43:05 am »
Well my swept VNA recommendations aren't going to work at/below 0.1Hz. You'll need an FFT-based approach with DC-coupled inputs. Choice of test signal might be interesting... what do you have in mind?
Offline rhb
« Reply #25 on: May 29, 2018, 02:03:23 am »
Use a DSO and analyze the data using Octave/MATLAB on a PC.  You'll need to collect long records to make up for the 8 bit ADC, but if it won't you can take care of that by collecting  a large number of records. This is dead simple.
You're down below my normal neighborhood of reflection seismology and into earthquake territory.  Though in all failrness, the oil industry is doing a lot better below 10 Hz than we used to.
Purpose built machines are great if you have to do a lot of the same stuff, but for a one off there are cheaper options that are not difficult.
Offline Insatman
  • Country: ph
« Reply #26 on: May 29, 2018, 05:53:56 am »
What I am testing is a 01.Hz to 10Hz bandpass 10000x amplifier used to measure the noise on precision voltage sources in the VoltNut area of this Blog.   What I have been doing thus far is using my modified FY6600 signal generator and a lot of 20dB attenuators to generate a small enough signal at specific frequencies from 0.05Hz up to about 20Hz.   I measure each frequency on an oscilloscope and plot the results manually.  It's a slow process and yields only a few points...but good enough to measure the frequency response.   i'm hoping for a better/automated way to do this with greater granularity.
A 2nd application is to charactorize some low-pass filters I've been making for general lab use.   These have cutoff frequencies from a few kHz up to 200Khz.   So the soundcard solution would only cover the low end.  My SA is spec'd down to 9KHz but is really a bit flakey below 100KHz or so.
Offline CEHymowitz
« Reply #27 on: September 27, 2018, 07:07:30 pm »
Hands Down OMICRON LAB Bode 100. Both a VNA and an FRA. 1-50MHz, $5490
https://www.picotest.com/products_BODE100.html
Independent Review
Offline Gerhard_dk4xp
« Reply #28 on: September 27, 2018, 07:47:25 pm »
but he wrote < 1 MHz, not 1MHz - 50 MHz.
I currently have the same problem, in that my ZVB-8 starts only at 300 KHz ( 150 KHz overrange )
I have written a program to do Bode plots with my  Agilent 89441A, but that turned out to be a lot more more work than I hoped for. It gets tricky to achieve a nice dynamic range down in the 1/f region.
regards, Gerhard
Offline JohnG
« Reply #29 on: October 22, 2018, 02:57:09 pm »
The Omicron unit is 1 Hz to 50 MHz.
John
