I was measuring a 7805 regulator yesterday and instead of 5.00V DC I got 5.31V! Well, I know scopes are not the best for DC voltages, but is not too much off? I decided to test every one of those 4 inputs and every input gave me different results for the 5V regulator:
IN1 = 5.31V
IN2 = 5.04V
IN3 = 4.82V
IN4 = 5.01V (the only one which match my calibrated Fluke 187!)
Is this normal or my Agilent scope is bad?
First off, performing a Self-Cal as others have suggested will probably improve things a fair bit on your most divergent channels.
But to answer your questions directly:
a) no, that's not too far off, and
b) yes, it's normal, and
c) it's within spec (a question you didn't explicitly ask, but was implied)
Is it normal a 5% error in DC with a new unit which specs says 1%?
I'm curious where you got the impression it has a 1% error spec? From the datasheets I have, it says 3% of FS, over 10mV/div.
I don't know what settings you were using, but if we keep it simple and say 2V/div, with 0 offset, that's 16V FS. 3% of that is 0.48V. All 4 of your channels are within that spec. (Actually, there's an additional 0.25% FS error term, which would make it 0.52V, max rated error). So Agilent only claims it will be within ~10% of reading at 5V, and they all are well within that range.
Your average error is 2.7%, dominated by your worst channel (6.2% of reading, 1.9% of FS). A Self-Cal will improve that, but still is unlikely to get you anywhere close to 1% of reading. 2% of reading here (+/-0.1V) would be very good indeed. Expecting it to "
match my calibrated Fluke 187" is completely unrealistic.
