Ouch. Hope you figure out a fix."
"WTF... You poor bugger. Scream long and hard and they might rescue you for good publicity."
"oh dear This is putting me right off agilent, they should NOT be treating people like this..."
"Updates should always be free ... It would be great for competition to see this on a YouTube channel."Interesting. Before we all grab our torches and pitchforks, and storm Agilent HQ, it might be wise to keep in mind this is a report from a member with one post, who's been here for 10 days.
I'm not saying he isn't completely on the up & up, and I do sympathize with his situation if so. But the situation he's described isn't the
only scenario that could have gone down.
For instance, speaking only hypothetically, someone could have read about all the hacks that have been done to Rigol scopes, and in particular the BW upgrade on their 1000-series, years ago. Realizing that the Agilent scope they had was made by Rigol, and possibly had a lot of firmware aspects in common, one might be tempted to do a bit of experimenting to see what was possible (200 MHz, maybe?).
Now, even on the Rigol's, you had to be very careful when sending these commands into the unit, because they were implemented so poorly. I.e., no error checking. So if you make a mistake, you can't correct it. This was even worse over serial than USB, because folks would try and backspace to correct typing errors... only that didn't actually erase anything! And the end results? Munged Model and SN strings in their scopes. Even typing too many characters could screw them up, big time, because there was no bounds checking.
Who knows what might happen on the Agilent's? The commands are there, because I just looked at the binary. So one goes looking for older versions of the firmware, which might function differently, and allow one to recover. Possibly not, but what do you have to lose?
As I said, I'm NOT stating that's what actually happened. But it seems like a more plausible scenario to explain the current situation. And once someone had gotten themselves into that uncomfortable position, it would be logical that they'd like to have the scope vendor bail them out, for free.
