Author Topic: Agilent U8032A mini-teardown  (Read 2827 times)
Offline simingxTopic starter
  • Country: sg
« on: July 24, 2014, 10:34:22 am »
Don't turn it on, take it apart!
The U8032A is one of Agilent's "low-cost" offerings, it's a 375W triple-output supply (0-60V, 0-3A x2 and 5V 3A).
http://www.home.agilent.com/en/pd-2054589-pn-U8032A/triple-output-dc-power-supply-60v-3a-2x-375w
It's able to do basic output sequencing by switching between 3 memory outputs, although an E36xx it isn't.
Surprisingly, it's a switch mode design. It is rather heavy though, at almost 9kg's.
Didn't go into too much detail, the internal boards are not easily taken apart, and it isn't exactly mine  >:D
Sorry for the poor images, I used my mobile phone for them...
Front panel
Rear panel with large 120mm fan. Yes it's a bit noisy, as you'd expect.
Chemi-Con KX main filter capacitors
Mains filter and wiring
Main bridge rectifier and some TO-220 devices (preregulation?)
Small toroid for auxiliary supplies. I thought it might be the main transformer, but that doesn't look like it can supply 375W to me...
STM32 micro for front panel
Main PWM control chip
5V output control section
Top side of 5V output. You can see the capacitor hanging off the output 2 jacks... afterthought?
Primary side of one of the main 60V 3A output boards. Secondary side is obscured by filter components, and I wasn't going to disassemble the unit further...
Control section for main outputs. That's quite a lot of horsepower (AT91SAM7X128)!
Pretty LCD panel  ;D
That's all for now, if you guys want anything more let me know and I'll try to get a picture if I can access it.
The following users thanked this post: trebejo, sfs1
