I managed to get my hands on a really rare, outside of industry at least, piece of kit this week: an Agilent/Keysight Acqiris U1081A (AP200). Couldn't find any close up pictures online, so decided to make some. As a small side note: I haven't actually been able to test it, on account of the exuberant fan duct bouncing into my graphics card. I currently don't have any thermal grease, so I can't take it apart (yet). But rest assured that's coming! For now already a sneak peak though. These seem to be sufficiently rare that you can't even find a proper datasheet on the U1081A (AP200). Luckily the one of the U1082A is quite similar, and the user manual contains the full specifications.
It has two input channels and an external triger, and will do 2 GSa/s with 500 MHz of bandwidth on one channel with 500 mV full scale, a maximum 2V offset, and possible 25 MHz . While inherently 8 bit, they can use
averaging (there's more behind it) to increase this to 12 bit. It's capable of holding 256k 8 bit samples, and it can do quite a few fancy averaging things - for which I still have to read the manual. Trigger response time is about 18.8 ns. So in short, it's pretty much an oscilloscope (minus the frontend) in PCI card format. It sucks a mere 56.6W out of your computer, and is fully capable of (ab)using DMA to ship the samples off to greener DRAM pastures.
PCB Backside:
Top side (heatsink):
Side view:
Back panel:
Macro images of the back side:
More coming later!
