Author Topic: AN8008 US $19, 9999count, 1uV, 0.01uA, 0.01Ohm, 1pF resolution meter  (Read 299274 times)
Offline evavaTopic starter
  • Country: cz
Hi, recently I saw new meter on ebay - less then half the price of UT61e, 1uV instead of 10uV resolution, interesting.
http://www.ebay.com/itm/AN8008-True-RMS-Digital-Multimeter-9999-Counts-Square-Wave-Voltage-Ammeter-/282496420913?epid=0&hash=item41c6194c31:g:7SAAAOSwi7RZKRTd
Although without logging..
Who will be first to teardown?
« Last Edit: June 29, 2017, 12:07:27 pm by evava »
The following users thanked this post: edavid, RedSky
Offline Fungus
Re: AN8008 US $19, 9999count, 1uV, 0.01uA, 0.01Ohm, 1pF resolution meter
« Reply #1 on: June 29, 2017, 12:26:44 pm »
Is that a new model of those cheapo meters?
Looks intriguing, does it have a square wave output?
Update: Yes it does - read the description (duh!)
"*Square Wave Output:50Hz/100Hz/200Hz/300Hz/400Hz/500Hz/600Hz/700Hz/800Hz/
900Hz/1000Hz/2000Hz/3000Hz/4000Hz/5000Hz"
The AN8001 has been analyzed to death here, I assume it's quite similar inside.
https://www.eevblog.com/forum/testgear/aneng-an8001-6000-count-true-rms-multimeter/
« Last Edit: June 29, 2017, 01:13:21 pm by Fungus »
Offline Fungus
« Reply #2 on: June 29, 2017, 12:55:34 pm »
It has a uA range, which the AN8001 is lacking. And 9999 counts.
I bet all the people who rushed out to buy the AN8001 a few months ago will be upset by that.  :popcorn:
« Last Edit: June 29, 2017, 12:59:14 pm by Fungus »
Offline Wytnucls
« Reply #3 on: June 29, 2017, 01:10:48 pm »
Pretty impressive, if safety is not a concern.
Apparently, does temperature too:
Offline Fungus
« Reply #4 on: June 29, 2017, 01:25:11 pm »
Yep.
I was thinking about getting an AN8001 for Arduino club but lack of uA bothered me. This is much better, I might have to take the plunge.
All the review videos show decent autorange speed, fast continuity test, etc. It even does true RMS up to 1kHz and comes with lots of accessories and a bag.  :P
Offline Fungus
« Reply #5 on: June 29, 2017, 01:34:22 pm »
Regarding safety: The AN8001 was badly designed. It has an "OFF" position right next the the "mA" position. I bet the person who put in two "OFF" positions thought he was being clever, but... :palm:
In this new AN8008 the "OFF" position is far from the low impedance ranges - which is as it should be, especially for places like Arduino club. :)
« Last Edit: June 29, 2017, 01:40:26 pm by Fungus »
The following users thanked this post: sarahMCML
Offline Fungus
Offline Wytnucls
« Reply #7 on: June 29, 2017, 01:46:53 pm »
You mean like the 121GW?  ;D
Offline Fungus
« Reply #8 on: June 29, 2017, 01:57:22 pm »
The 121GW doesn't share the mA socket with the V socket, but yes, it's still bad design. Even if the leads are in the right place you have to switch past a bunch of other ranges (eg. Ohms) to get to the voltage ranges. Not ideal if the leads are connected to something at the time.
Comments, Dave?
« Last Edit: June 29, 2017, 02:03:25 pm by Fungus »
Offline EEVblog
« Reply #9 on: June 29, 2017, 02:02:41 pm »
Not an issues when the mA range is on it's own socket.
Only the uA range shares the V jack.
Offline EEVblog
« Reply #10 on: June 29, 2017, 02:10:58 pm »
Comments, Dave?
I like having the 2nd OFF position. Having only one in the traditional position makes your meter Voltage range racist  8)
If you do a lot of current measurement then the right hand off position can be handy.
Of course you can simply ignore the extra OFF position if it bugs you or doesn't suit your usage.
I kinda like the look of this cheap meter for basic budget low level electronics work, but if it's like the 8001 inside then it's your typical cheapie, albeit a bit more useful than most with those extra ranges.
The following users thanked this post: Marco1971
Offline EEVblog
« Reply #11 on: June 29, 2017, 02:20:07 pm »
Out of curiosity I've ordered one.
The following users thanked this post: 001, TheNewLab, pi^2, shteii01, Marco1971, bill_c
Offline Fungus
« Reply #12 on: June 29, 2017, 02:21:50 pm »
It's still a small issue, IMHO.
If you want to add value, get rid of both of them and put in a proper mechanical on/off switch.  :)
These new ones seem to have really good performance for auto-ranging, continuity, etc. The previous generation were horrible for that.
I really like the look of this one. I'm not sure what I'd use the square wave output for though.
(Can it flash a LED? Will it make a speaker buzz?)
Me, too.
« Last Edit: June 29, 2017, 02:24:15 pm by Fungus »
Offline Fungus
« Reply #13 on: June 29, 2017, 02:28:24 pm »
I can use the meter to switch my device on and off, it's a feature!
« Last Edit: June 29, 2017, 03:36:08 pm by Fungus »
Offline RedSky
« Reply #14 on: June 29, 2017, 02:38:16 pm »
I've ordered one too out of interest.
Ordered from a cheaper seller, here:
http://www.ebay.com/itm/AN8008-Multifunctional-Digital-LCD-Display-Multimeter-with-Combination-Wires-/152592869605?epid=0&hash=item23873e68e5:g:1D4AAOSwd~RZSLmV
Approx $20 (aud) inc shipping after conversion.
Offline Fungus
« Reply #15 on: June 29, 2017, 02:46:37 pm »
Neener, neener. I hope yours takes longer to arrive.
Snif.
Online kripton2035
« Reply #16 on: June 29, 2017, 04:52:01 pm »
you can find it as low as $15 ...
Offline Fungus
« Reply #17 on: June 29, 2017, 04:57:09 pm »
RedSky got his for even less than that.  :popcorn:
Offline kalel
« Reply #18 on: June 29, 2017, 06:28:18 pm »
Is there some specialized site for Chinese multimeters we're not aware of, or perhaps deals simply differ from country to country?
Offline retrolefty
« Reply #19 on: June 29, 2017, 06:40:05 pm »
With just one current probe position is there but one highest range current fuse?
Offline sleemanj
  • Professional tightwad.
« Reply #21 on: June 29, 2017, 09:34:49 pm »
Nice,  addition of uA makes it a lot better. I bet it will still have those silly little 10mm fuses though :-/  I ended up buying leaded ones from RS and cutting the leads off.
Offline casinada
The following users thanked this post: edavid, Flenser, IanMacdonald
Offline kalel
« Reply #23 on: June 29, 2017, 10:30:33 pm »
or more generaly :
https://www.ebay.com/sch/i.html?_from=R40&_sacat=0&LH_BIN=1&_nkw=an8008&_sop=15
Ah, okay, the price diff is because shipping is country specific (so some will see better deals than others).
Offline sleemanj
« Reply #24 on: June 29, 2017, 10:39:40 pm »
casinada beat me too it, but following the info from the 8001 thread ( https://www.eevblog.com/forum/testgear/aneng-an8001-6000-count-true-rms-multimeter/ ) and searching kazus.ru for 8008 gets us to this thread ( http://kazus.ru/forums/showthread.php?t=112135 ) which mentions it as the Zotek ZT109 / Aneng 8008 / Autotool DM700 as what appear to be the most recent ones added to the list
Quote from: kazus.ru
Zotek ZT109 (Aneng AN8008, Autool DM700).
For sure the list is not complete and as information is received it will be supplemented.
The newest modification of the DTM0660 chip is DM1106EN
(references to the new version of this chip are viewed from the end of the 16th year).
It seems it has been around since at least mid-may when this post was made : http://kazus.ru/forums/showthread.php?p=1122373
This post I think has the EEPROM dump from the 8008, google translation isn't so helpful "By the way, since the speech went for innovations, I can say that the AN8008-go (ZT109) on the arena all the same. And the problems of 9999 are also present, but there it is possible to select ranges manually."
http://kazus.ru/forums/showpost.php?p=1126917&postcount=1827
First couple posts in this page
http://kazus.ru/forums/showthread.php?t=112135&page=184
I'm not quite grokking the machne translation totally but I think they are taking about some issues
Note that the temperature mode is not enabled, it needs to be added by reprogramming the eeprom.
Teardown photos on this post are of the 8008
http://kazus.ru/forums/showpost.php?p=1127606&postcount=1854
« Last Edit: June 29, 2017, 10:58:12 pm by sleemanj »
The following users thanked this post: 3db
