Author Topic: Aneng AN8008 multimeter fuses  (Read 11153 times)
Offline gthorudTopic starter
« on: October 21, 2018, 04:05:08 pm »
Has anyone found a place to buy fuses for the AN8008 at a reasonable price? (In my case postage and taxes on it is high from major suppliers.)
Fuses are glass fuses with white content, diameter 3.6mm length 10mm. 0.2A and 10A. I assume quick. I have not meassured the resistance yet.
Geir
Sent fra min EVA-L09 via Tapatalk
Offline JDubU
« Last Edit: October 21, 2018, 04:48:24 pm by JDubU »
Offline Mr. Scram
  • Display aficionado
Re: Aneng AN8008 multimeter fuses
« Reply #3 on: October 21, 2018, 06:34:04 pm »
This raises the question: fast blow fuses or slow blow fuses?
Offline HKJ
    • Tests
« Reply #4 on: October 21, 2018, 07:42:10 pm »
In multimeters you always wants fast blow fuses. They are not supposed to handle any over range inrush current, but blow before the shunt or protection diode do.
« Reply #5 on: October 21, 2018, 10:07:24 pm »
I have ordered the 10A fuses, linked to above, from Ebay, let us see what they are.
It is difficult to find QUICK 0.2A fuses.
Bying from Mouser is an option, but the postage causes them to cost about the same as a new AN8008.
I meassuerd the fuses in my AN8008:
0.2A 0.80 ohm
10A around 0.01 ohm.
Thanks for the help so far!
Geir
Offline meebro
« Reply #6 on: October 22, 2018, 03:37:46 pm »
https://www.aliexpress.com/store/product/10A-600uA-fuse-for-RM101-102-multimeter/909123_32811804077.html?spm=2114.12010610.8148356.2.60fb5987OT65XM
These fuses should work for the an8008. Richmeter and aneng meters are supposedly made by the same OEM if i recall correctly. The 200mA seems to be $0.96 shipped for me.
The following users thanked this post: TurboTom
Offline indman
  • Country: by
« Reply #7 on: October 22, 2018, 04:34:42 pm »
Hi, guys! For what do you suffer with such children's fuses?  :D  Only several minutes are required to establish holders for  fuses of the standard size. I have performed such operation for  the multimeter RM101.
The following users thanked this post: 001
Offline meebro
« Reply #8 on: October 22, 2018, 05:40:03 pm »
Sadly, the distance between the fuse holders are very small in the an8008-9 and there are some melfs and screws in the way as well.  |O
Offline indman
  • Country: by
« Reply #9 on: October 22, 2018, 06:49:24 pm »
Nothing will be an obstacle if to arrange new holders as I have shown on a photo ;D
The following users thanked this post: Electro Detective
Offline Fungus
« Reply #10 on: October 22, 2018, 07:45:59 pm »
The rest of the world pays $15 shipping on mouser/RS/etc. (minimum).
Offline meebro
« Reply #11 on: October 22, 2018, 08:50:31 pm »
Oh, i was talking about the aliexpress link, Mouser shipping varies a lot of course.
Offline TurboTom
« Reply #12 on: October 22, 2018, 09:30:20 pm »
I think since it's common sense not to use these meters on high-energy circuitry, it's like shooting cannons on birds to replace the existing fuse sockets in order to be able to install real HRC fuses, if suitable ones are available (just ordered a mix of 30 3.5*10mm fuses shipped at the price of one HRC fuse). I consider these fuses inside these meters rather as a means to protect the meter from stupid mistakes of the user and not the user from potential explosion (of the meter)/ injury. If there's chance for the latter to happen, the user didn't quite understand something...  >:D
The following users thanked this post: meebro
Offline indman
  • Country: by
« Reply #13 on: October 23, 2018, 08:28:23 am »
TurboTom, I only suggested one of methods to get rid of children non-standard fuses. It is possible to use fuses of the standard size, it is possible ceramic, it is possible from glass which roll near at hand in a large number. :D
Good luck to you guys in acquisition of children's fuses! |O
« Last Edit: October 23, 2018, 08:31:21 am by indman »
Offline stj
« Reply #14 on: October 23, 2018, 01:21:03 pm »
20mm FF rated SIBA fuses - with excess copper removed from under the fuses to prevent arc-over.
if your gonna do it - dont hold back!  :)
The following users thanked this post: indman
Offline TurboTom
« Reply #15 on: October 23, 2018, 02:11:03 pm »
@indman The situation for me is like that: I must have got about a total of five of the tiny meters (different models) distributed in my home, car and field-access tool box so it's never far to get one, simply since they are so versatile. Actually, I never blew a fuse on any of these. But to me, it's just too much hassle to replace all the fuse sockets in all of them. I rather spend ten euros on 30 suitable "children" ;) fuses of different ratings and put them in the magazine so I've got spares just in case.
For mains work, I anyway use one of my two Flukes or maybe the surprisingly well made Peak Tech 3440 (CEM DT-989).
Peace  :D
« Last Edit: October 23, 2018, 10:13:46 pm by TurboTom »
Offline stj
« Reply #16 on: October 23, 2018, 02:37:59 pm »
the fuses are only used for current ranges anyway.
Offline Fungus
« Reply #17 on: October 23, 2018, 06:02:59 pm »
Some people read current with their multimeter...
« Reply #18 on: October 23, 2018, 09:56:14 pm »
Thank you VERY MUCH for the link to aliexpress. I will try them.
Compared to other sources this will probably be 1/10 of the cost compared to main streem suppliers, the shiping cost far too much.
If they are bad, I will modify for longer fuses.
I have been aware of the high voltage issue with these short fuses, but I have other meters for that purpose.
Geir
Offline riccardo.pittini
« Reply #19 on: January 13, 2019, 07:05:45 pm »
I made the same mod to fit 5x20mm HRC fuses on a AN8009 the problem is that it is necessary to re-calibrate the multimeter as the current measurement can be affected  :)
Offline floobydust
« Reply #20 on: January 13, 2019, 07:18:57 pm »
It's only if you change the PCB and soldering path to the shunt resistors.
The fuse resistance does not affect the calibration. You have pics of your mod?
Offline Fungus
« Reply #21 on: January 13, 2019, 08:59:43 pm »
The only thing it can affect is the burden voltage.
Offline HKJ
    • Tests
« Reply #22 on: January 13, 2019, 09:06:17 pm »
Have you seen where the sense wires for the current shunt are connected? (This can affect the 10A range, but not the uA range)
Offline Fungus
« Reply #23 on: January 13, 2019, 09:24:20 pm »
Burden doesn't come only from the shunt, it's the entire path through the meter from input to output.
Offline HKJ
    • Tests
« Reply #24 on: January 13, 2019, 10:34:39 pm »
It has nothing with burden voltage to do, but where you connect a updated fuse to the circuit board.
