Author Topic: Another cheapo multimeter: 19999 count, 0.05% DC accuracy  (Read 51332 times)
Offline HKJ
    • Tests
Re: Another cheapo multimeter: 19999 count, 0.05% DC accuracy
« Reply #50 on: April 17, 2018, 06:07:45 pm »
Thank you. The first teardown big picture is missing
I had type the wrong picture number, it is fixed now.
The AN870 seems to have about twice the usable frequency for TrueRMS, half a digit extra on most measurements, otherwise very similar.
How do you get that, they both drop just above 2kHz, i.e. RMS needs considerable lower frequency to work.
PS: how well does the NCV tester work? Can it detect wires in walls?
I have a wall without wires in that most NCV tester signals on. NCV is fairly difficult to compare because how you hold the meters is one of the parameters for sensitivity. If you have your hand around the meter and the wire is just behind a very thin wall it might give alarm.
Online Fungus
« Reply #51 on: April 17, 2018, 06:16:47 pm »
Looks like the accessories vary with brand....  :popcorn:
Offline 001
  • Country: aq
« Reply #52 on: April 17, 2018, 06:53:03 pm »
Can I  power AN870 with two AA NiMH cells ?
Online Fungus
« Reply #53 on: April 17, 2018, 06:54:18 pm »
The AN860B+ is 5% down at 1kHz, 12% down at 2kHz.
(although it is quite linear up to 2kHz so you can still take measurements if you know that)
You say the AN870 is 5% down at 2kHz, that's half as much.   :)
Online Fungus
« Reply #54 on: April 17, 2018, 06:55:30 pm »
The test says:
Meter works down to 2.2V where it turns off, battery symbol show at 2.4V.
So it's your call.
(2.4V is quite high though, maybe this meter is suitable for Batteroo Batterisers!  8) )
« Last Edit: April 17, 2018, 06:57:09 pm by Fungus »
Offline 001
  • Country: aq
« Reply #55 on: April 17, 2018, 06:57:08 pm »
 No?  :-//
Offline HKJ
    • Tests
« Reply #56 on: April 17, 2018, 06:59:59 pm »
You cannot use the full runtime of them, the meter says empty battery at 2.41V, that would mostly work.
The following users thanked this post: 001, MF-jockey, MT
Offline HKJ
    • Tests
« Reply #57 on: April 17, 2018, 07:03:23 pm »
My numbers says 2kHz and 5% for both meters, measured with a sinus. It is a fairly high order filter.
A square wave is only about 10% different from a sine wave.
Online Fungus
« Reply #58 on: April 17, 2018, 09:03:18 pm »
I was using a square wave, maybe that's the difference.
Offline 001
  • Country: aq
« Reply #59 on: April 17, 2018, 09:59:56 pm »
 what about temperature compensation ?
Offline HKJ
    • Tests
« Reply #60 on: April 18, 2018, 03:59:46 am »
Thats fairly standard with a temperature sensor inside the multimeter chip. The linearization for temperature input is good, it basically works from -200 to +1300°C
Offline HKJ
    • Tests
« Reply #61 on: April 18, 2018, 07:29:03 am »
As it says at the bottom of the review I got this meter from Banggood and after my review they decided to add some discount (I do not now if they raised the price before they did that  :) ), details are on my frontpage (Click globe).
Offline 001
  • Country: aq
« Reply #62 on: April 18, 2018, 09:54:37 am »
is it same circuit as qn860 or not?
Offline HKJ
    • Tests
« Reply #63 on: April 18, 2018, 11:29:12 am »
It is basically the same as AN860B+
Offline 001
  • Country: aq
« Reply #64 on: April 18, 2018, 11:50:50 am »
Is it DTM0660 based?  :o
Offline HKJ
    • Tests
« Reply #65 on: April 18, 2018, 11:54:20 am »
It is rather difficult to read the type number on a COB chip and I am not going to check the contents of the EEPROM.
Offline Stinger
« Reply #66 on: April 18, 2018, 10:29:27 pm »
Thank's for your job.  :-+
And about wrong temperature mesurement of AN860B+ brother ?
Offline 001
  • Country: aq
« Reply #67 on: April 20, 2018, 06:20:27 pm »
What about  AN860B+  temperature?  :-//
Online Fungus
« Reply #68 on: April 20, 2018, 07:00:52 pm »
I never had any problems with it.  :-//
Offline HKJ
    • Tests
« Reply #69 on: April 20, 2018, 07:06:19 pm »
Probably somebody that do not know how thermocouplers work, there are a couple of pitfalls.
I wrote a bit about it here: https://lygte-info.dk/info/DMMThermocouplers%20UK.html
The following users thanked this post: mos6502, 001, Stinger
Offline gpu7990
  • Country: ua
« Reply #70 on: May 02, 2018, 07:23:06 pm »
Hello, can someone read eeprom from zt219 or AN870? Thanks
Offline lordvader88
« Reply #71 on: May 02, 2018, 09:16:17 pm »
So what's the verdict ? I need a 2nd DMM for breadboard level stuff and for upto 240V mains heaters/hotwater boilers, once in a blue moon. And I don't want to take my quality DMM out of my house.
So for $50 is a good choice for that ?
Offline Johnboy
« Reply #72 on: May 02, 2018, 10:20:21 pm »
The consensus seems to be that these cheapos, while useful for extremely low-current, low-voltage work, are not suitable for working with mains.
I do not think anyone here would suggest that the meters discussed in this particular thread can be considered "safe" for household use, let alone industrial applications. If safety is your concern, that is what you are paying for, not the meter.
I'm interested in this model because of what it can do at the lowest ranges, but I wouldn't trust my life to the diaphamous input protection on the device when working with higher voltages, and I don't recommend you do either.
« Last Edit: May 02, 2018, 10:28:10 pm by Johnboy »
Offline maginnovision
« Reply #73 on: May 02, 2018, 10:21:18 pm »
I am fairly certain one of mine died at 120v. The leads are junk and there is little protection in the meter. Get something else.
Offline lordvader88
« Reply #74 on: May 02, 2018, 11:04:57 pm »
Yeah rewatching some of Joe Smith's testing video's (of others), this thing has no amount of input protection MOVs or PTCs.
