Author Topic: Another cheapo multimeter: 19999 count, 0.05% DC accuracy  (Read 51412 times)
Online Fungus
Re: Another cheapo multimeter: 19999 count, 0.05% DC accuracy
« Reply #75 on: May 02, 2018, 11:24:15 pm »
So what's the verdict ? I need a 2nd DMM for breadboard level stuff and for upto 240V mains heaters/hotwater boilers, once in a blue moon. And I don't want to take my quality DMM out of my house.
So for $50 is a good choice for that ?
If it really is "once in a blue moon" then you'll live. Just make triple-sure:
a) The leads are in the correct holes,
and
b) The dial is on the voltage range.
(a) Is maybe the most important. You can get it right by measuring a 9V battery before you start.
Offline coromonadalix
« Reply #76 on: May 03, 2018, 10:15:33 am »
the verdict to me ,  buy an good brand meter, good input protection, good behavior   etc etc ...  for a little more $$ you have some well built mastech models, and the fuses and batteries are easily removables  the 8240 or 8340 ??? 22000 count dmm, but i think they have changed the revision model, and removed a fuse, mine was an 8240d if i recall corectly and had 2 hrc fuses ??? and data logging features too
theres a thread for some mastech meters and pictures of them
https://www.eevblog.com/forum/testgear/mastech-ms-8233e-ms-8240d-and-ms-8250c/
« Last Edit: May 03, 2018, 10:17:34 am by coromonadalix »
The following users thanked this post: Netsniper
Offline spidola
  • Country: ua
« Reply #77 on: May 16, 2018, 02:36:07 pm »
Is the speed of AN870 / RM219 measurements anywhere close to UNI-T UT61E? Or how much does it differ from the previous models? I am looking at RM303 / ZT303 that should be similar in performance.
« Last Edit: May 16, 2018, 03:20:44 pm by spidola »
Offline HoracioDos
  • Country: ar
  • Just an IT monkey with a DSO
« Reply #78 on: June 13, 2018, 04:36:55 pm »
is there an ANENG equivalent for this model?
Offline joeqsmith
« Reply #79 on: June 19, 2018, 11:40:56 pm »
I've been watching videos of people making modifications to their UPS's and came across this video.    ANENG in a zip lock bag.   I wonder what their concern is.
https://youtu.be/GFiIovqdBwY?t=2262
Offline Gregg
« Reply #80 on: June 20, 2018, 03:04:30 am »
The ANENG meter was probably a sizeable investment to the person in the video and they wanted to protect it in case of a lithium battery incident.  Not unlike the patented Joe Smith meter coffin to protect everything but the meter when destructive testing is happening (only in reverse).
Offline ez24
  • L.D.A.
« Reply #81 on: June 20, 2018, 03:16:07 am »
I wrote a bit about it here: https://lygte-info.dk/info/DMMThermocouplers%20UK.html
Added link to List C - it will show up in the next upload
Offline spidola
  • Country: ua
« Reply #82 on: June 20, 2018, 04:47:37 pm »
It does not look like there one yet.
Offline HoracioDos
  • Country: ar
« Reply #83 on: June 20, 2018, 05:13:36 pm »
There's a TMI meter in a ziploc bag also @57:25. I think that plastic bag purpose is to protect the meter from environment not to protect her from the meter.
Offline HoracioDos
  • Country: ar
« Reply #84 on: June 20, 2018, 05:21:19 pm »
If I read the specs correctly 60mA range is also missing like Q1.
Online Fungus
« Reply #85 on: June 20, 2018, 06:35:11 pm »
Just get the ANENG 860B+, it's the one to get!  :popcorn:
Offline joeqsmith
« Reply #86 on: June 20, 2018, 11:25:48 pm »
You could very well be right but if the packs come apart, how much protection does a zip lock bag really offer?   Maybe when they spot weld they get some splatter and the bag is enough to stop it.
Offline maginnovision
« Reply #87 on: June 20, 2018, 11:53:11 pm »
I don't have an 860B+ but I still think you might be right. Neither of the 2 870 I bought held up to 120v mains and basic accuracy testing. That's pretty bad despite accuracy being pretty good. The Q1 has a neat screen but that's about it for that one. I bet that relay dies WAY before you'd expect too.
Offline flywheelz
« Reply #88 on: July 16, 2018, 01:22:23 am »
I was set on ordering ZT302 but few here recommended ZT301 over ZT302. The latter is missing 10mA and 100mA but the former is missing 1mV range that 8008/8009 have right? So no 1uV resolution?  How useful is it to have 1mV range that has 3 decimal points?
Now I think I might hold on for ZT303/AN303/RM303 to go on sale.
« Last Edit: July 16, 2018, 01:51:18 am by flywheelz »
Offline edmundopt
  • Country: pt
  • There's theory and practice...
« Reply #89 on: July 31, 2018, 10:46:46 pm »
I have received my Zt219, here are some pictures of it
The following users thanked this post: 001
Offline 001
  • Country: aq
« Reply #90 on: December 30, 2018, 07:01:13 am »
Any news?
Offline spidola
  • Country: ua
« Reply #91 on: January 04, 2019, 11:48:52 pm »
Any news?
Yes, I purchased RM303. It is a nice meter. However, the speed of measurements is on par with the other meters of this price category, it is not as fast as in UT61E.
« Reply #92 on: January 05, 2019, 06:16:07 am »
Damn thats a cheaply "non protected inputs meter", i would not play with voltages greater than 50vdc / 50vac ...
Does the words  "security / user safety"  resonate somewhere ??
Offline HKJ
    • Tests
« Reply #93 on: January 05, 2019, 07:36:25 am »
That protection is fairly standard in cheap meters and will often handle up to about 230VAC.
Offline edmundopt
  • Country: pt
« Reply #94 on: January 06, 2019, 08:28:14 pm »
I have a U1273A as my main multimeter
as my 3rd multimeter this one is actually pretty good, to be used in  battery/bench psu powered devices
Offline magic
« Reply #95 on: January 12, 2021, 11:53:35 pm »
Is that high impedance millivolt range on those Anengs of any use or just a gimmick?
Does it show zero with a wire between the input jacks? Does it still show zero with a 1Meg resistor? ::)
Somebody said that voltages below 5µV are rendered as zero :palm:
I suppose that's to hide the meter's offset voltage. What happens to this "helpful" feature in REL mode? Does it activate when the displayed value is below 5µV? Does it activate when the actual input voltage is below 5µV? Does it just go away?
Offline ledtester
« Reply #96 on: January 13, 2021, 12:03:22 am »
From the comments:
1150300-0
The following users thanked this post: Gregg
Offline magic
« Reply #97 on: January 27, 2021, 05:49:18 pm »
So I know the answer now:
REL at anything within ±4µV - nothing changes
REL at -5µV: the display goes -1, 0, 5, 10, 11
:-DD
