No it's not a simple 2 in 1 solution like to combine
a scope with an arbitrary waveform generator in one box.
With a MDO you can work with the two domains
time and frequency at a time-correlated base.
Thank you for the Videos.
Now I understand what they mean with "Mixed domain". That's a TEK-only Marketing-Term, isn't it?
I used similar Instruments (especially Analyzer with Spectrogram), but without a scope... RF only. A syncronized scope-channel may come in quite handy.
Btw, I tested some these big LeCroy scopes some time ago, they are quite good despite the rather cheesy spot
But that are not the typical Hobby-Scopes. If you want that, you have an application that demands it.
Meaning: 12 Bit are nice. For several applications with post-processing of the waveform it may be a killer.(*) But most of the application of a scope don't demand them, 8 Bit are OK. In the marketing (as always) they boost the importance as world-moving or whatever
(*)Of course depending on the analog performance of the front-end. Who needs a 24Bit ADC if the first 20 are noise?
