It is the same unit as the Jaycar 'scope I bought a few years ago---cost me $A135 at the time.
The idea was to use it to fix my BWD,which has about the same bandwidth,but a nice big display in a not much larger package.
As it happened,I did find the BWD fault,(loss of triggering) but the faulty parts were so hard to get at,that I put it on the back burner,& just used the Jaycar.
You can do a lot of good work with a basic CRO like this---I even took it to work,as they didn't have a working 'scope,only an old dead Tek 545B,with no normal plugins,only a spec an.
It was very useful for troubleshooting in low frequency & DC circuits.
Used it at home to look at up to 27MHz signals at reduced amplitude,look at Engine Control Module pulses in cars,etc.( not as easy as using a battery DSO,but useable).
Things that go wrong:-
(1) The knobs are rubbish,& will break after a while---just find,or buy some generic knobs,& all is well.
(2) the plastic shaft of the focus pot broke off,but it is hollow,so you can stick a screwdriver into what remains & set the focus OK.
(3)The vert input BNC came unscrewed,& broke its connecting wire off---The thread isn't long enough,so I replaced it with a generic BNC from the junk box.
(4) V1 or V2 (can't remember which) in the EHT supply failed.(Think the "D880"stands for 2SD880.)
Not readily available,but there were two transistors in the same packages in a salvaged TV SMPS,which looked like they might be suitable.
I was going to use them both,but botched the desoldering on one,so just used the remaining one to replace the faulty device.---two different transistors,but there's not much to lose!
Away it went,EHT back to normal,CRO back in service.
So there you go--a bit "rough-n-ready",easy to fix,& quite useful .
You paid too much,though--you could have had mine for a lot less!
