your link works fine
http://www.flir.com/instruments/content/?id=70502Most sample images are resized.
As attachment an original image. Open it with Flir Tools etc.
Raw Thermal Image Width : 1024
Raw Thermal Image Height : 768
Raw Thermal Image Type : PNG
ExifTool Version Number : 9.91
File Name : FLIR-T1K-IR-Failing-Connection-Indsutrial-Breaker.jpg
File Size : 851 kB
File Modification Date/Time : 2015:09:09 09:45:58+02:00
File Access Date/Time : 2015:09:09 09:45:58+02:00
File Creation Date/Time : 2015:09:09 09:45:58+02:00
File Permissions : rw-rw-rw-
File Type : JPEG
MIME Type : image/jpeg
JFIF Version : 1.01
Exif Byte Order : Little-endian (Intel, II)
Make : FLIR Systems AB
Camera Model Name : ___________________
Orientation : Horizontal (normal)
X Resolution : 72
Y Resolution : 72
Resolution Unit : inches
Software : 0.9H.1T
Modify Date : 2015:08:07 10:55:54
Y Cb Cr Positioning : Centered
Exposure Time : 1/34
Exif Version : 0220
Create Date : 2015:08:07 10:55:54
Components Configuration : -, Cr, Cb, Y
Subject Distance : 30.48 m
Focal Length : 35.8 mm
Image Temperature Max : 312
Image Temperature Min : 307
Flashpix Version : 0100
Color Space : sRGB
Exif Image Width : 1024
Exif Image Height : 768
Digital Zoom Ratio : 1
Image Unique ID : F0A605A23889E626D891BF6F40990617
Compression : JPEG (old-style)
Thumbnail Offset : 1908
Thumbnail Length : 9831
Creator Software :
Emissivity : 0.95
Object Distance : 30.48 m
Reflected Apparent Temperature : 20.0 C
Atmospheric Temperature : 20.0 C
IR Window Temperature : 20.0 C
IR Window Transmission : 1.00
Relative Humidity : 50.0 %
Planck R1 : 14623.098
Planck B : 1439.655
Planck F : 1
Atmospheric Trans Alpha 1 : 0.006569
Atmospheric Trans Alpha 2 : 0.012620
Atmospheric Trans Beta 1 : -0.002276
Atmospheric Trans Beta 2 : -0.006670
Atmospheric Trans X : 1.900000
Camera Temperature Range Max : 150.0 C
Camera Temperature Range Min : -40.0 C
Camera Model : ___________________
Camera Part Number : _______________
Camera Serial Number : 72500041
Camera Software : 1.0.0
Lens Model : FOL36
Lens Part Number : T198938
Lens Serial Number :
Field Of View : 27.3 deg
Filter Model :
Filter Part Number :
Filter Serial Number :
Planck O : -4385
Planck R2 : 0.012720319
Raw Value Median : 15250
Raw Value Range : 668
Date/Time Original : 2015:08:07 10:55:54.907-07:00
Focus Step Count : 12511
Focus Distance : 1.1 m
Palette Colors : 224
Above Color : 170 128 128
Below Color : 50 128 128
Overflow Color : 67 216 98
Underflow Color : 41 110 240
Isotherm 1 Color : 100 128 128
Isotherm 2 Color : 100 110 240
Palette Method : 0
Palette Stretch : 2
Palette File Name : /FLIR/usr/etc/iron.pal
Palette Name : Iron
Palette : (Binary data 672 bytes, use -b option to extract)
Raw Thermal Image : (Binary data 666210 bytes, use -b option to extract)
Real 2 IR : 1.56011033058167
Offset X : -70
Offset Y : +10
PiP X1 : 0
PiP X2 : 1024
PiP Y1 : 0
PiP Y2 : 768
GPS Map Datum : WGS84
Embedded Image Width : 1280
Embedded Image Height : 960
Embedded Image Type : JPG
Embedded Image : (Binary data 86341 bytes, use -b option to extract)
Image Width : 1024
Image Height : 768
Encoding Process : Baseline DCT, Huffman coding
Bits Per Sample : 8
Color Components : 3
Y Cb Cr Sub Sampling : YCbCr4:2:0 (2 2)
Image Size : 1024x768
Megapixels : 0.786
Peak Spectral Sensitivity : 10.0 um
Shutter Speed : 1/34
Thumbnail Image : (Binary data 9831 bytes, use -b option to extract)
the real image
> exiftool FLIR-T1K-IR-Failing-Connection-Indsutrial-Breaker.jpg -b -EmbeddedImage > real.jpg
