Author Topic: Multimeter probe caps  (Read 582 times)
Offline SpacedCowboyTopic starter
  • Aging physicist
« on: March 03, 2023, 08:19:56 pm »
Having just stabbed myself (right on a knuckle-joint!) with the exposed red probe below, I am thinking that getting a replacement for the missing cap for the end of the red probe (like on the black one) would be a good idea. Apparently my google-fu is not up to scratch, because I can't find anything that doesn't want to sell me an entire new probe-set.
Has anyone any idea where I can get the small grey plastic thing that stops me drawing my own blood when fiddling behind the shelving on which the multimeter is stored ? Many thanks if so :)
Offline TimFox
Re: Multimeter probe caps
« Reply #1 on: March 03, 2023, 08:31:19 pm »
Maybe something from this catalog section?  Or one of the adjacent sections in their catalog.
https://www.mcmaster.com/products/cap-plugs/cap-type~push-on/
The following users thanked this post: SpacedCowboy
Offline BillyO
« Reply #2 on: March 03, 2023, 09:20:35 pm »
A bit of insulation stripped off some wire might do the trick until you find something better.
« Last Edit: March 03, 2023, 09:37:29 pm by BillyO »
Want to see an old guy fumble around re-learning a career left 40 years ago?  Well, look no further .. https://www.youtube.com/@uni-byte
Offline Miti
« Reply #3 on: March 03, 2023, 09:33:54 pm »
Look for SMA dust caps. Some are pretty long, they could be exactly what you’re looking for.
Or search Ali for Rubber Sleeve Stopper Silicone Glue Insulating End Caps.
« Last Edit: March 03, 2023, 09:37:36 pm by Miti »
Fear does not stop death, it stops life.
Offline BeBuLamar
« Reply #4 on: March 03, 2023, 09:36:32 pm »
How often you need the sharp tip probe? If not so often I would remove the probes and have regular probes the won't draw blood.
  • Aging physicist
« Reply #5 on: March 03, 2023, 10:33:00 pm »
Thanks for the ideas, all - the mention of silicone tips made me think of the silicone tubing I have for the fish tank airline. That has now solved the problem for the time being even if it's not particularly pretty :)
