Hi All,
I just bought the 5MHz function generator directly from China. It took 2 weeks for delivery. I had emailed with a Sales Engineer beforehand, and contact was OK. So I bought it despite that the fact that very little information is available over the internet.
The unit came with an USB cable, a CD (software and manual), 2 BNC to croco cables, and a US style power adapter (I am in Europe, but what the heck). So all OK.
Interface has 8 buttons and a rotary dial. It functions very intuitively. The software on the CD installed OK (you need to unpack the archive onto a separate stick, or so, for installation. Otherwise, the installer will not find files. You can download the pack also at
http://www.mhinstek.com/down/html/?80.html -- Chinese page, but English software version). The core of it is a National Instruments Lab View module. Not fancy, but functional, clean and quick to understand. To get sorted on the basic functions was easy. For "specialties" like burst, sweep, frequency measurement it makes sense to look into the useful manual. FSK modulation I could not get to work, log sweeps are not possible though I found someplace that they should be. Arbitrary waveforms are very easy. You can draw by hand, or import a CSV form Excel.
How about signal quality? To put the following into perspective: In my previous life I used to work in an electrotechnical lab and operated all sorts of very expensive and high quality signal generators. Now I use a function generator only privately for hobby stuff. So I pay more attention to the bucks than for the bang. This said, I tested against a freshly calibrated Agilent Digitizing scope. I will only give qualitative impression here.
Stability was very good. As you may expect from a DDS generator the two channels are well linked to each other. Lissajous figure did not 'rotate' over time. Frequency I found accurate and stable. Output voltage I found almost 10% too low, but I could re-calibrate the device directly over the interface and the rotary dial (no trimmer poti needed). Afterwards I found voltage to be within a few percent for all frequencies, waveforms, duty cycles, and amplitudes. Distortion I did not check since for it is OK as long as a square looks like a square.
Conclusion: Good deal and perfect for my needs.
Best,
Jay
