Check if the outer bnc plugs are grounded together, if so you use the inner bnc pins for the kelvin clips and the 4 wires shield is put together near the kelvin end clips, to provide the shielding.
And if you equipment permit it, you null /zero out the value by shorting the kelvin clps together
