I have several 87's series I, III, V - just acquired an 87IV.
I know they were unpopular at introduction, changed to the 189 type, and the 87 re-introduced as the series V, but I do a lot of audio and the AC+DC
and dB functionality is really handy for audio.
Still lights a white LED and reads the diode voltage drop by the way. I found that a bit surprising.
Still getting the feel of it, but so far - I like it!
If you get a chance, please post what is the diode voltage output on that model when measured on another meter set to DC?
5, 6, 7 volts?
The 189 badged model would be the best no brainer high end meter I've used, akin to an 87V on ster0ids
Once you get used to this meter, you may want another, and you won't find one working cheap
Fluke got it right as a step up from an 87 and 8060A models, combining all the good stuff from those into one AIO meter
then went and dumped it for the 289
The 289 boat I like too
but they should have kept the 189/187 going alongside the 87 series, and close the buyers gap for choice (Fluke or...Fluke)
The 189 has everything you need on the front panel, no menu brainers to remember
or scribble on hand/arm/leg/chest/neck/private parts
..free removable really cool tattoos that serve a purpose
Who was smoking what at those Fluke 'what do we release next?' meetings?
Edit: anyone that's used the AutoHold feature on the higher end Flukes with the best and fastest continuity buzzer going,
is going to be a very fussy shopper if thinking about jumping ship...
