Eveready Enerjizzers leak any day because they can
FWIW the 87V with it's little 9v battery
has a diode test voltage that leaves most meters in the dust
7v IIRC
Out of all the meters I've had, almost none of the 9 volt ones leaked,
and any that did was an easy clean up
Just wait till a 189 or 187 goes Leak City, the stuff will eat it's way along the battery connectors and straight to the board
If the board survives, just pray you do too, once you see what the eaten away battery replacement parts cost
